Engine and ABS dash lights
Old Nov 25, 2008 | 06:03 PM
mohrd's Avatar
Default RE: Engine and ABS dash lights
Hey Trebor0301, nice to hear from you. Please takle a moment to introduce yourself and then I'm sure sombody will advise you to:
1 Get your codes read
2 Once you know what codes are, search the Forum for possible threads that may answer your queries.
3 Come on back and tell us what you've found or need help with.
4 Excuse me for being such a sh*t. Had to put my dog down today...looking for a distraction and somebody to take it out on. Nothing personal...
Old Nov 25, 2008 | 07:06 PM
BuckMR2's Avatar
Iys usuallyeither the common fault which is one of the rearspeed sensors rings on the outer cv joints or less likely the short length of wiringto one of the front wheel speed sensors.There is a how to check for the rear ones (usually brings up codes C1175 or C1165 depending on which side has corroded and loosened/come off).Cost to replace rear outer cv joint which includes the sensor ring is around £150all inc and cost to replace faulty wiring is around £10 for the wire from a dealer and £30 labour.
Old Nov 25, 2008 | 07:33 PM
mohrd's Avatar
Welcome aboard. Funny that there would be no codes stored if the CEL had been on as they should be stored until clear. The nice thing you'll find about this Forum is that for the most part any problems you've had someone else has had too. That's to say, you won't find many mysteries as most encounter the same few problems/diagnosis.
PS Pretty devastating after 15 years with the same pup...thanks for the sentiments.
Shawn Svacha
Nov 4, 2019 02:47 PM
Jimscriv
Nov 4, 2015 02:18 PM
jehart49
Sep 12, 2015 05:36 PM
stetson1
Aug 27, 2015 07:49 AM
NinoGrimace
Aug 26, 2015 05:15 AM
