Engine codes P0174 and P1000 what does this mean
Old Dec 17, 2008 | 09:29 AM
JagXV6's Avatar
Default RE: Engine codes P0174 and P1000 what does this mean
P1000 comes up all the time even if there are no other stored
fault codesso no need to worry about it.
Here is what you need to read concerning your other code:
https://www.jaguarforums.com/m_34490/tm.htm
Very common problem. NO it is NOT the O2 sensor so follow
the above info first.
Old Jan 2, 2009 | 10:51 AM
pad's Avatar
pad
P0174 is the 02 sensor at the front of the exhaust before the cat under the airbox. Mine had the same fault several months ago.
Old Jan 2, 2009 | 12:10 PM
JagXV6's Avatar
Ah, agian, it is NOT an O2 sensor problem. The O2 sensor "reports" a lean condtion
because extra (unmeasured)air is entering the intake from bad IMT O rings or cracked
vacuum hoses. This problem has been well documented here and Certifed Jag Techs
have attested that it is not an O2 sensor problem and indeed is an air leak issue.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 2, 2015 12:48 PM
