Engine fan will not turn off
Old Oct 25, 2015 | 11:01 PM
GrahamJagX's Avatar
Default Car booked in for tomorrow
Originally Posted by dwclapp
Graham: Did you get a chance to check the white / blue wire from the ECM to the Fan Control Module, per Dr dome's suggestion? With the engine hot and off, and the fans still running too fast and too long, check the voltage in the white / blue wire. If it's ~0V volts, this confirms the Fan Control Module must be bad. But if the voltage is closer to 12V, then the problem could originate in the ECM or the temperature sensor.
DW, I booked the car into the auto electrician today, I'm taking the car to them tomorrow where they will check the fan control module. I tried to contact Dr Dome re the control module but so far have heard nothing (it is the week-end). Hopefully it won't turn out to be too expensive.
Old May 5, 2019 | 09:53 PM
Kelso Grant's Avatar
Hi Graham,
Am having the same problem with my 05 X Type, was looking around online and see this help forum. What was the outcome, was it the Fan Control Module?
Old May 6, 2019 | 05:34 AM
Dr dome's Avatar
Default Control Mod
Yes it was the control mod. I do have some on the shelf if you need one. I just need your year jag so you get the right one.
Thanks,
The Dr
My cell is 484-903-4813
Old May 16, 2019 | 01:55 PM
ernieg's Avatar
I have a 2006 x-type with a 3 liter engine and my fan will not turn off. Have replaced the FCM twice and no change. Removed the ECM today, and even with that completely disconnected, the fan comes on full blast when the battery is connected. Until just recently, the car would start and run under this condition, but it now won't start and is showing "transmission fault". About ready to have it towed to dealer. Could I have bought two bad FCM's in a row?
Old May 16, 2019 | 04:05 PM
Dell Gailey's Avatar
If you bought the cheaper internet ones = yes. Look at the ones from Rock auto, etc. To get an OEM one.
Heed #10 & #11 =
https://www.jaguarforums.com/forum/x...module-201955/
Also, member Dr. Dome has used and tested modules he sells. He's a great source for parts.
Old May 16, 2019 | 04:44 PM
ernieg's Avatar
Heed #10 & #11 =
Thanks. They were. Will try one of the others!
Marka
22
Sep 11, 2016 12:09 AM
Msteiner
May 16, 2016 12:19 AM
studentper
Feb 20, 2016 09:43 PM
BruceL6901
Oct 2, 2015 07:23 AM
sandmann62
Oct 1, 2015 09:31 AM
