engine fault light on
Old Aug 4, 2013 | 09:11 AM
fourbyfourbyfar's Avatar
Default engine fault light on
hi all had the engine fault light came on today but everything fine! no limp home mode no fault codes tried restarting the engine a few times still on still everything fine drove to garage to get petrol filled up and started engine and light gone off??? any ideas what this could be. got 91k on the odo
Old Aug 4, 2013 | 02:41 PM
Jeeves12's Avatar
fourbyfourbyfar - Can you clarify which engine light - the yellow engine light or the message light? Can you have the codes read by a OBII reader and then post these? We need a little more information.
Old Aug 4, 2013 | 06:56 PM
Thermo's Avatar
Veteran: Navy
4x4x4, the CEL light will go off by itself if the problem condition has cleared itself and the car has been able to go through 5 start cycles and was run long enough for the computer to complete a drive cycle with each start. Then, on the 6th start, it will clear the light. So, it kinda sounds like your car hick-uped and it was enough to throw a code and now it is gone. If you are wanting to know what is going on, the code is still inside the computer. So, you can still pull the code up and see what the car was having a hissy fit over.
Old Aug 7, 2013 | 09:51 AM
how do i get the codes do i have to plug in a reader i read somewhere you pressed the trip button in while starting the engine. when i do this it comes up with test and then nothing it returns to normal
Old Aug 7, 2013 | 12:25 PM
harvey_birdman's Avatar
If you go to many auto parts stores such as Advance Auto they will read it for you.
Old Aug 7, 2013 | 01:44 PM
Thermo's Avatar
Veteran: Navy
4x4x4, if you have a reader, then all you do is with the car parked, plug in the reader (port is under the dash near the steering column, on a LHD car, it is between the steering column and the outside edge of the car, tucked just behind the bottom edge of the dash). From there, you turn the ignition key to the RUN (II) position and worst case, you will have to hit "READ" on the reader.
Yes, you can use the instrument cluster to get the codes, but it will give you a 4 character code in hexidecimal and then you have to convert that number into decimal to get the code and unless you are good with match, just plug in the code reader you have.
But, like was said, if you stop by your local auto parts place, they should plug in a reader for you and give you the codes for free. Let us know what you get and we can help you out a lot more at that point.
Old Sep 18, 2013 | 04:31 AM
hi all had the engine light come on again yellow one on display got the code now 1296 the light has gone off again it says multi faults bank 2 anyone know what this could be.the code in the dtc is E510 in hex which is 1296 what does the E mean???
toronadomike
Jan 22, 2026 10:13 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
TC Johnson
Sep 2, 2015 09:30 AM
daro31
Aug 27, 2015 09:26 AM
