Engine malfunction light
Old Dec 3, 2013 | 12:31 AM
levi_mumba's Avatar
Default Engine malfunction light
hey I have a jaguar x type 2.5cc 104,000 mileage. its showing a engine malfunction light, but the car is working just normal everything is working perfect, may anyone help to stop the signal?
Old Dec 3, 2013 | 12:38 AM
luisg707's Avatar
Welcome to the forums!
The check engine light comes on when the car's computer detects something wrong with the engine. What you have to do is either visit an autoparts store and have them use a scan tool or purchase one yourself. I highly recommend purchasing one because it will save you a ton of money in the future diagnosing your cat.
Just a FYI: I purchased this one not to long ago.
Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive
If you look benith the steering wheel on the left side you will see a port, you just plug in the scanner and it will scan your car and let you know the error codes that the engine's computer is reporting. Normally the codes are in the this format: Pxxxx where xxxx is a numeric value (eg P1646).
Give that a try and let us know the associated error codes so we can pinpoint what the problem is. Also using a scanner tool you can 'erase' the code that's the system is reporting which will temporarily turn off the check engine light. after 5-10 minutes your car will most likely do a full check and the light coming back on.
Good luck!
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
TC Johnson
Sep 2, 2015 09:30 AM
