Engine Mount
Old Nov 27, 2020 | 05:58 PM
JagXtypeV63.0L's Avatar
Default Engine Mount
I have a clunk when I start to accelerate from a stop. I believe it's my engine mounts. Any suggestions on good jaguar x Type engine mounts at a goo price?(also I've never fixed engine mounts is it an easy job, or should I hire a mechanic?)
Old Nov 28, 2020 | 07:19 AM
Thermo's Avatar
Veteran: Navy
JagXtypeV63.0L, the first thing you need to do is figure out which one of the 4 engine mounts it is that is giving you grief. Odds are, you are looking at more than 1 if you are hearing a clunk. If you are not sure, then a simple check is to open the hood of the car, put your foot on the brake (and HOLD IT THERE) as you gently apply a little bit of gas (not a lot). If you have a broken engine mount, you will know as the engine will try and remove itself from the engine bay (hence the LITTLE BIT of gas). Granted, have you looked at the centering bearing on the rear driveshaft. I would suspect that long before an engine mount.
As for replacing an engine mount, not a tough job, but you need some very specific tools. The big one being a cherry picker. NEVER!!!! lift the engine by putting a jack under it. It is very easy to damage something down there like the oil pan. After that, you lift up slightly on the engine to create a small bit of room and then you can replace a mount. Not many people have a cherry picker at their disposal.
Higgins
Feb 20, 2019 05:50 PM
philc850
Nov 29, 2016 04:10 AM
Britrover
Mar 10, 2016 10:49 PM
kyle04
Sep 26, 2013 06:51 AM
XJ40 ( XJ81 )
May 16, 2005 08:19 PM
