engine system fault
Old Jul 22, 2010 | 09:19 PM
Jerry the Jaguar's Avatar
Default engine system fault
Today while i was driving i suddenly got a engine system fault message, and the car would not accelerate. I pulled over and turned it off. The first couple of times i started it, the same message came back and it was idling around 1500 rpm. After a few more starts, the message went away and the car drove fine the rest of the day. This has happened once before, about six months ago. Please tell me this isn't the throttle body!
Old Jul 22, 2010 | 10:03 PM
echosixnovember's Avatar
Bring it in to get looked at. I had a DSC fault and a Cruise Fault kick off, combined with a check engine light. It also used to slam into neutral then start beeping out of control, where i decided after about 5 rounds of that nonsense that i needed to bring it into the shop. Had to buy a coil pack and a wheel speed sensor... it was a gooooooood couple of pennies to fix, but it cured the problem. faults are something I wouldn't play around with. at least have it looked at by a "professional" and decide what you want to do from there. Nobody on this forum will be able to eliminate a fault error
D.K
Dec 10, 2023 02:05 AM
arnoldmilk
Sep 3, 2015 07:42 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
TC Johnson
Sep 2, 2015 09:30 AM
