Engine tempature warning red light is on
Old Apr 30, 2012 | 08:36 AM
drock138's Avatar
Default Engine tempature warning red light is on
I have a 04 x-type 3.0s. When I opened the door of my car this morning the alarm sounded and As I drove the car the High tmepature warning was showing on the display with a red light. THe meter was on hot with red light also. No Steam, spray, change in the car at all. I have not checked anything yet. I will start with fluid check. Any ideas about what else it could be and how to fix it.
Old Apr 30, 2012 | 08:45 AM
disguay's Avatar
Overheating on an x type is a faulty fan control module 9 times out of 10
Old Apr 30, 2012 | 11:48 AM
Thermo's Avatar
Veteran: Navy
drock138, like disguay said, most of the overheat issues stem from a bad fan controller. I have to ask whether the car was overheating when out on the highway or did it start overheating after a period of in town driving?
If the car overheats on the highway, then you are looking at most likely a bad water pump, but can also be a bad thermostat. If the car only overheats in the city, then you are most likely looking at a bad fan controller.
If you want to prove the fan controller good, let me know. The check is really easy to do.
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
JeffR1
Sep 12, 2015 10:43 AM
ahunt4
Sep 4, 2015 02:59 AM
Spikepaga
Aug 30, 2015 12:59 PM
