Engine wires
Old Dec 23, 2021 | 02:30 PM
Squito's Avatar
Default Engine wires
2005 X-type 3.0L U.S.
Replacing the water pump and came across two wires in the engine bay that seem to lead to nowhere (see pic).
One was connected to the underside of the battery box. It has a light green and light blue wire. The battery box receptacle is a dead end.
The other was located under the fuel throttle body assembly and just hanging loose. It has a brown (or purple) and black wire. The other end appears to dive under and between the manifolds headed toward the timing belt end of the engine (or it could dive down toward the radiator).
Can anyone provide insight as to the purpose of the wires and what they should be connected to? Vehicle runs fine with them not connected.
Thanks in advance. Happy holidays to you all.
Squito
Engine bay wires X-type 3.0L
Old Dec 23, 2021 | 07:45 PM
Thermo's Avatar
Veteran: Navy
Squito, the wires on the back of hte batty box are from when the car was shipped over from England. Those were used to maintain the battery charged. Connect them back to hte battery box and call them good. As for the other connector, I am not sure what that would be for. I would have to get back home and look at the diagrams to see if I could match up a connector.
Old Dec 27, 2021 | 09:52 PM
Squito's Avatar
Thermo,
Hope you had a good holiday and are safely home.
Any more thoughts on the wire? Best I can tell it goes into a wrapped wire bundle underneath the throttle body.
Thanks in advance
Old Dec 28, 2021 | 01:27 AM
Dell Gailey's Avatar
Can't tell the wire colors because of the dirt. Are they red & green? If so, most likely the TPS sensor.
Old Dec 28, 2021 | 09:56 AM
Squito's Avatar
Dell, as noted in the original post, it is a brown (or purple) and black wire. It was not connected to anything and the engine/car runs fine with it hanging loose.
Old Dec 28, 2021 | 09:59 AM
Thermo's Avatar
Veteran: Navy
Squito, not back yet. But, like was asked by Dell, if you can look at the wires and get the specific colors, that would help a lot. Some of the wires will have a colored stripe on them. These are normally referred to using the process of the main color being first then the second color (stripe) color with a slash between the two. So a blue wire with a red stripe would be written as Blue/red wire.
Old Apr 22, 2022 | 10:15 PM
Squito's Avatar
Update on this thread....
Still looking for assistance as to identification of the brown (or purple) and black wire in the area beneath the throttle body and duct.
The light green and light blue wire has been identified as a trickle charge when shipping the car.
Thank you.
Old Apr 23, 2022 | 05:50 PM
h2o2steam's Avatar
Squito,
Is it the connector that goes to the ignition capacitor?
On my variant the capacitor is located on small bracket attached to engine below throttle body intake flexible pipe.
Red/white stripe and black wires so doesn't match your picture entirely but location is similar.
Old Apr 24, 2022 | 05:15 PM
Squito's Avatar
Originally Posted by h2o2steam
Squito,
I see the connection on my vehicle that you refer to and that's different. The car operates fine...I would think not if it were the ignition capacitor.
Xjeffs
Jul 18, 2021 03:05 PM
wheelmang
Nov 24, 2017 09:33 AM
1964Daimler
Aug 6, 2016 05:51 PM
LBWhit
Mar 25, 2015 11:18 PM
Jagxjs
Jan 20, 2013 07:25 PM
