Error code P0251
Old Nov 2, 2009 | 11:39 AM
BuckMR2's Avatar
Most people here are not from the UK so wont have diesels (diesel never sold in USA/Canada)
Somone on the co.uk forum had this and it was a blocked fuel filter causing that code and the same issues
When was the fuel filter last changed?
Try changing it and see if that cures it
Old Nov 3, 2009 | 06:54 PM
BuckMR2's Avatar
You could try wrapping some duct tape around the intercooler pipe while youre waiting for the replacement as a temp fix and I think you may well have hit the nail on the head with the problem.
Taped a split with duct tape on a pipe on my 3.0 X type which cured juddering and not being able to rev over 3k and problem went away.New pipe fitted a few days later.
Old Mar 28, 2014 | 10:40 AM
billdrives's Avatar
Did you ever get to the bottom of this problem as i have the same but my car cuts out whilst driving and P0251 is the code this throws up?
Old Mar 28, 2014 | 11:57 AM
Welcome to the forum billdrives,
You've posted to a five year old thread so starting a new one for your P0251 code issue is likely to get a better response.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Feb 11, 2015 | 02:23 PM
rjh39's Avatar
Default did u get a reply? same with my 08 x type? help
Did u get a reply, cant find this Q on new members!, and same with my 08 x type, Engine Management> cut out > code P0251 & P1211 - help!
Old Jul 17, 2018 | 10:54 AM
xarvi's Avatar
Hello everyone, let me start with this I had also P0251 and I fixed it, but how I got is more interesting. I was driving my Jag x-type 2.0d 300k km out of town, when I got battery warning light on my dashboard. I stopped and opened the hood and what I saw pieces of my auxiliary belt and pulleys everywhere ( later on I found one of the pulleys had broke a bearing and rest is history, but no indications of this .... ) so the car was fine and decided to continue driving on battery power. I reach a city near by, I have relatives there, they borrow my 2 other batteries and started to move on to my home town 150 km away (135km on highway) I reach the highway start driving with 130km/h so far so good. But when I wanted to accelerate the car limp and I check engine and flashing glow plug light. While driving power off the car then power on and everything back to normal. This happened few more times so I decided it is related to the low battery power or something like this. So I reach home, buy everything needed replaced everything, clear all errors on the car ( without checking them, because pretty much everything was affected due to low battery power) with Launch and leave the garage. Accelerate and again limp mode and low power....when car was on idle it was different there were more vibrations inside. I checked the car and I have only P0251 nothing else. I read a lot in the next few days, I found spare(second hand) fuel regulator valve, I prepare bottles for injectors return fuel test and new fuel filter. My EGR was cleaned 2 weeks ago so I was confident it is good. I replace the filter start the car and it sounds perfect I take it to a ride and no more p0251. So 1 week later still perfect, I was sure it is related to the blow of the pulley and belt, but at the end my filter was clogged.
So start cheap repairs first and verify the new conditions... good luck
Old Jul 31, 2018 | 01:25 AM
xarvi's Avatar
Update on the case, car was good for 3 days then back to limp mode and blinking glow light. I drain the fuel replace the filter and same issue again. Check with diagnostic and what I saw is sometimes car has steady idle 230 bar, but sometimes is 170-200-250-300 bar and constantly moving. I replace with cheap spare sensor the one of the fuel rail - no change then I replace the fuel pressure regulator on the fuel pressure pump and success car working fine, perfect idle !
Old Sep 15, 2018 | 03:32 AM
xarvi's Avatar
Update on the case, the resolution was temporary, I mean when the engine is cold I don't put so much pressure on it so no limp modes. When it is hot 1,2,3 gear pedal to the metal and limp mode again.... I do a new leak off test in cold engine the result are even better, equal levels of fuel of the 4 injectors (I can attach pics even) So far:
1. Replaced Fuel pressure sensor *second hand - no change
2. Fuel filter 2 times bosch and mann - no change
3. Fuel pressure regulator valve *second hand - no change
4. EGR - clean - no change
5. EGR repalced *second hand - no change
6. Catalyst converter - removed and clean (it was in very good condition) - no changed
7. ECU reset ( if the videos in internet are valid - jump cable between positive and negative terminal of the battery of course with battery disconnect )
8. MAF replaced *second hand - no change
9. Camshaft possition sensor replaced with new one - no change
10. Fuel tank opened and cheked for anything that can obstruct the lines - no change very clean ...
11. Obtain fuel pump from crashed jag second hand looks good final point to repalce the pump I am looking for good manual how to do it, espacialy the timing chain.
some remark my turbo doesn't have actuator fully mechanical and EGR is only with vacuum pile no sensors
Old Jan 30, 2019 | 03:23 PM
jomac_uk's Avatar
Exclamation
You mentioned a belt and pulleys breaking, did you fix that and make sure the alternator is charging properly???
You can get with a faulty battery or a poor charge from the alternator, many different codes appear because of this. Make sure the batter is OK and charging at the correct voltage before you start looking for faults from codes which don't exist, caused by electrical issues
Old Jan 31, 2019 | 02:26 AM
Luke Farrell's Avatar
Get the new intercooler pipe first and see if that helps.
then get loads of oil like wd40 and spray it all over the turbo actuator to loosen it up, mine got stuck a bit before and the car goes into limp mode (safe mode) when you accelerate hard. The oil will loosen it. If you could get someone to rev the car while you spray on the oil even better.
if the new hose doesn't help the black smoke then your EGR valve could be going.
my car had a lot of black smoke when mine was failing and used to jerk the car at a constant speed. Other times the car would hesitate and blow out loads of black smoke when the power came back.
I ended up blanking off the egr valve until I got a new one and then the new egr valve went too after a week , it must have been poor quality lol
Old May 5, 2019 | 12:23 AM
xarvi's Avatar
Hi guys I forgot to update you on the story:
at the end I gave up and went to Bosch service - they weren't exactly specialize in Delphi but they know the right guy so long story short - fuel pump was wear and small
metal debris to the injectors.
So the pumg got new "head", realease valve and one more thing I don't remember , Injectors were recycled also and after 1200Euros the car is good as before.
It seems this issue did came slowly because now the acceleration is very smoth and the start is how we called it here "half key" very fast ...
So I am happy with the car again. The car is around 190K miles I have it from 6 years(73000miles) and except that no other major failures.
Old May 5, 2019 | 12:30 AM
xarvi's Avatar
One of the first things I done was to check the pipes and they were looking good, after one month after I fix the car, suddenly I lost power and black smoke start- the hose beneath the
EGR got a crack, after replacement all good.
My turbo is the old one with the vacuum valve and it was moving fine all the time. I am using fuel additives all the time and I can say that the pipes and turbo were very clean, just a thin layer of soft carbon.
Other than that during the years I done 2 carbon cleanings of the engine with Hydrogen and the results were very good ( here is very cheap around 30euros)
Bcrary3
Feb 21, 2023 04:29 AM
Terry H
Jul 4, 2017 05:48 PM
KarimPA
Sep 27, 2015 08:46 AM
Jpav27
Sep 26, 2015 03:33 PM
tonyforman
Sep 10, 2015 07:23 PM
