Exhaust Sound
Old Apr 28, 2010 | 11:32 AM
Jaggyx's Avatar
Default Exhaust Sound
Hey guys,
Some of my friends have been messing around with there exhaust on the BMW's at the muffler shop and they happened to make there exhaust burble or bog when they let of the throttle. I have Magnaflow mufflers welded in so the sound is already pretty nice but I'm just wondering if theres anything I can do to achieve this bog sound when I let off.
Old Apr 28, 2010 | 09:03 PM
Disco stu55's Avatar
do u have a example, maybe a youtube video?
Old Apr 29, 2010 | 12:34 AM
Jaggyx's Avatar
here is an example I found, I don't expect something as dramatic but I do want some of that exhaust pop.
http://www.youtube.com/watch?v=pqP9t6_P7UY
Old Apr 29, 2010 | 05:15 PM
ufoz8mycow's Avatar
Basically if you want that exhaust popping noise, you need bigger exhaust piping. Youll be making more noise, and youll lose some low end power.. But itll make the noise you want.
Old Apr 29, 2010 | 10:20 PM
Jaggyx's Avatar
hmm I dont know if I want to sacrifice power for noise, but its something I'll keep in mind. What size piping would I need?
Old Apr 30, 2010 | 06:57 AM
The Chris X's Avatar
I don't really think you want to do this, as ufo said you need some backpressure for torque development. If this was a turbo car then it would be pretty easy to get the rasp, but it's not.
So let's say you want to do this anyway but not spend much, you could try go in through the tailpipe with a long spade bit, maybe 1", and perhaps try to bore out some of the flow chamber. A schematic of the inner structure of your existing muffler would be helpful, then you could see if you could reach perhaps the main deflector with a long bit and a drill.
Or hack your good stuff off, slap a couple of Thrush cherry bombs on there, hate the noise 99% of the time but get lots of pops and cracks.
Old Apr 30, 2010 | 10:24 AM
Jaggyx's Avatar
Well this doesn't sound very appealing anymore. My friend was complaining that he could feel some low end power gone, so I think Ill just live without the popping.
Old Apr 30, 2010 | 11:28 AM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
In days of old, we would use a gadget called a "Laker Cut-Out" for the effect (and more) you are seeking.
They still make 'em: http://www.jcwhitney.com/cast-iron-e.../p2006307.jcwx
Might be a fun mod to install, make a Jag sound like a friggin' tractor!
Old Apr 30, 2010 | 12:01 PM
Thankfully for the good ole' days, emissions inspections were not required. As JaggyX appears to be Cali, I don't think they would fly unless he can figure out a way to get his X titled as a classic or a kit car or some other loophole.
Interesting that many high end manufacturers are using a simlilar technology to the Lakers these days, I believe the new Ferrari Italia has a two stage exhaust where it can be programmed/commanded to open another exhaust outlet for additional flow, and yes, noise! Not quite a Laker, but similar.
Old May 1, 2010 | 03:41 PM
PreJag's Avatar
LOL. Get an old ignition coil, wire it thru a toggle switch, drill a hole in the exhaust pipe under the car and thread in a spark plug. Run a lead from the coil to the plug......when you hit the switch, any unburned gases ignite making one hellof a pow! Prob more burble than you want.......and really tough on mufflers.
WhiteTardis
Jan 14, 2019 02:47 PM
Daim
Nov 28, 2016 09:28 AM
08Z06
Oct 24, 2015 05:46 PM
tampamark
Sep 14, 2015 09:12 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
