External temperature display
Old 03-12-2008, 12:18 AM
jvegas's Avatar
Default RE: External temperature display
it could be very hot outside? lol!! I don't know. i am sure someone will be by soon to help you.
Old 03-12-2008, 06:20 AM
You either have a bad ambient temp sensor or the control module is taking a dive. The temp sensor is easiest to replace and cheapest. If you look down at the lower bumper vains you will see a little switch attached there. Thats the ambient temp sensor. They don't go bad too often, so be prepared for some $$$ outlay if it turns out to be module. Good news is you can always use a used one as long as you get it programmed to vehicle after install. See them on Ebay fairly often. The control panel is the module.
Old 03-12-2008, 10:55 AM
ruslan35's Avatar
Hope this helps some: location of that sensor
Old 03-12-2008, 02:29 PM
Dennis's Avatar
ud
You all know the difference between an Rectal thermometer and an Oral thermometer?
.Yup..it's the TASTE[:'(]
Old 03-12-2008, 03:32 PM
sick. LOL
Old 03-18-2008, 09:39 AM
[sm=roll.gif]
I've got the same temp problem....I just put it off to the Fla. Sun! I'll check it tonight.
Old 03-18-2008, 09:19 PM
Where in FL?
GGabriel
11-22-2018 03:53 AM
flyingv65
10-01-2015 01:54 AM
workworkwork
10-01-2015 01:44 AM
Quick Reply: External temperature display
