Factory radio
Old Nov 18, 2018 | 07:12 AM
hlotero's Avatar
Default Factory radio
Hello, I know this is a simple question for you, but any help will be appreciated.
Can I replace my factory radio from another xtype same basic radio with different part #,please let me knuw, thanks.
Old Nov 18, 2018 | 07:22 AM
Thermo's Avatar
Veteran: Navy
hlotero, depending on the market that you are in, this can be easy, it can be difficult. The radio swap is easy. A few screws, a few plugs and then the radio can go back in. Where the difficulty comes is that in some markets, Jaguar placed security stuff into the radio to make it worthless if you don't have the radio code to reactivate the radio once it has lost power. For example, if you are in the US, then you are golden, no code required. If you are in England, code is required. As for other places, that is going to be hit and miss. This is where you may want to have a piece of paper from the wrecking yard saying that you have legally purchased the radio from car with VIN XXXXXXXXXXXXXXXX which has been removed from service and is being dismantled. So, if you should need to get the code, that should be enough to allow jaguar to get you the code. If you do some looking around here, I think there is a way to back door the radio, but I am not recalling what it is.
Old Nov 18, 2018 | 07:30 AM
hlotero's Avatar
Thanks Thermo, yes the market is USA, the screen of my radio was damaged by the Sun and there no display att all. I found some original factory replacements on ebay but with different part numbers.
Old Nov 18, 2018 | 11:49 AM
Thermo's Avatar
Veteran: Navy
hlotero, as long as they are all coming out of US market cars, you should be golden. With that being said, you need to replace it with the same model radio. This is not a time that you can go from a basic radio to a NAV radio. The NAV radio has a completely different harness and lots of other stuff that has to be added to make it work correctly. If the face looks the same, then you should be good.
Old Nov 20, 2018 | 05:53 AM
luka000's Avatar
If you find radio outside US there is easy way to bypass radio code:
"Enter any code 3 times so that the display shows "PLEASE WAIT"
Simultaneously press ">>" "PTY" "A.MEM" should only take 2 or 3 seconds and the radio turns on "
bob5tafford
Dec 19, 2021 04:10 PM
phd12volt
42
Feb 4, 2021 11:54 PM
mrreason
Feb 11, 2013 05:05 PM
dmiller1023
Jan 17, 2011 08:37 AM
wolv2401
May 5, 2009 05:09 AM
