Fan Control Module
Old May 20, 2018 | 11:31 AM
nj-jag's Avatar
Default Fan Control Module
Hi Guys,
My wife's 2006 X Type 3.0 V6, fan keeps running so I replaced the fan control module twice. However, the new fan control modules don't seem to be working.
The first one they said was only for a 2.5l so I returned that and got one that says it is for the 2.5 and 3.0, but that one fails to work as well.
For both of the replacement units the fan never came on. Even when the car temp passed the middle. I didn't let the car run much after the temp got to this point, but it sounded like the fans tried to shut on, but couldn't. However, when I put the old one back in it just runs at high speed. This lets me know the fan motors are fine. So now I am at a loss.
Anyone have any ideas?
Pictures are first the side of the old control module, the new control module and the old control module.
Thanks,
Attached Thumbnails Fan Control Module-old-fan-control-unit-side.jpg   Fan Control Module-new-fan-control.jpg   Fan Control Module-img_20180520_122300.jpg
Old May 20, 2018 | 03:49 PM
dwclapp's Avatar
nj-jag: Do an advanced search of this forum for "Fan Control Module" by user "Thermo". Fortunately I haven't had to replace this part, but many have because the electronics fail with heat & age, so used fan control modules are frequently bad for that reason.
I assume your coolant level is correct and the ECT (Engine Coolant Temperature) sensor working properly. If the coolant drops below the ECT sensor, hot steam from the low coolant tricks the ECM into 'thinking' the engine is too hot and instructs the fan control module to run the fans at full speed even after you turn the engine off.
This forum has many posts on this topic, because it's common for our aging X-Types.
Old May 20, 2018 | 06:06 PM
wa3ra's Avatar
Before you go crazy, check the fuse!
Old May 21, 2018 | 11:38 AM
nj-jag's Avatar
From everything that I have read on the forum, it is my fan module.
I did the trip button and the multimeter tests and they both point to the fan control module as well.
Since the fans are running I know that fuse F40 is working. I also had the fan running with the car off and pulled F16 and the fans continued to run. This again is pointing to a fan module.
The units that I purchased and that didn't work were supposed to both be new aftermarket units, not used units.
Has anyone successfully used an aftermarket module?
Thanks,
Old May 22, 2018 | 09:27 AM
Larry-Cleveland's Avatar
Hi
When you solve the odd problem and have a bad module laying around I would love to have it. I want to rip it apart and document the repair of them.
Let me know and I will send you a prepaid shipping label.
Old May 22, 2018 | 08:37 PM
Jag4's Avatar
Buy another module from a good source. I've know other owners to get two bad ones.
Old May 25, 2018 | 05:35 PM
nj-jag's Avatar
Ok. Just finished trying my third fan control module. This one was from a 2006 x type and was supposedly tested for 14 days prior to me receiving it.
I installed the new module and the fan didn't come on at all, with AC on full blast and I let it run until the temperature got passed midway. Still the fan didn't come on.
Replaced the old module and the fan immediately started,but at full tilt.
The saga continues.
If anyone can think of other things to look into it would be appreciated.
Old May 25, 2018 | 05:36 PM
nj-jag's Avatar
If anyone has any good sources for the fan control module, I would appreciate it.
Old May 27, 2018 | 06:59 PM
Jag4's Avatar
Have you checked the electrical, and cleaned the connectors? Make sure everything is plugged in correctly. My replacement unit wasn't plugged in correctly which caused my fans to come on with the ignition.
You could repair the one you have or ask someone to fix it. Make sure the electrical is ok, Thermo details this out in this or another thread.
This stuff can be frustrating, eliminate one thing at a time. I'll keep in mind a source.
Old May 29, 2018 | 09:59 PM
Dell Gailey's Avatar
Old May 29, 2018 | 10:00 PM
Old May 30, 2018 | 06:48 AM
nj-jag's Avatar
Funny, I did search on Rock Auto but I used the Part Number on my unit which was 940.0040.00.
Does anyone have any experience with this unit?
Old May 30, 2018 | 06:51 AM
nj-jag's Avatar
I thought the same thing about the way it was plugged in, but I can't see how it isn't plugged in correctly. If you can give any insight on how yours wasn't plugged in correctly that would be great.
In the meantime, I will recheck the electrical and clean the connectors.
Old May 30, 2018 | 04:55 PM
https://www.rockauto.com/en/moreinfo...036&cc=1416013
Old May 30, 2018 | 04:59 PM
Old May 30, 2018 | 05:04 PM
Old Jun 21, 2018 | 03:00 PM
nj-jag's Avatar
Thanks. I got sidetracked with an O2 Sensor issue right when the car needed to go for inspection. That is done now and I am going to try the part from RockAuto. Wish me luck.
Best,
Old Jun 25, 2018 | 01:35 PM
nj-jag's Avatar
The unit from RockAuto worked like a charm. Removed old unit and installed new unit in about 15 minutes and tested. So far so good.
Thanks for all the help.
Best,
Old Jun 25, 2018 | 04:12 PM
Nice
Old Jul 18, 2018 | 04:25 PM
Jag4's Avatar
Originally Posted by nj-jag
Hi Guys,
Thanks,
Fixing / refurbishing the original control module would be my next move.
afonda
Sep 5, 2012 11:43 PM
blackcat2003
Aug 10, 2011 05:59 AM
Green Machine
May 2, 2011 06:34 PM
afonda
Jan 27, 2011 11:54 AM
hawaiibill
Oct 5, 2010 10:23 PM
