First I was excited and gitty . now i scared and sad.
Old Nov 8, 2019 | 07:20 AM
Lynae's Avatar
Default First I was excited and gitty . now i scared and sad.
I bought an older jag last week and already its giving me sighns to sell . intell i found this site . have found hope in all the info here . my jag is having the common jag flu . cruise not available , shakes when accelerates and now squeaky brakes .. ��
Can someone guide me where to start please .
Dont want my first jag to be a drag . ( ya i am a little corny )
_________________
2003 X-Type
Last edited by GGG; Nov 8, 2019 at 07:34 AM. Reason: Add Model & Year details from later post
Old Nov 8, 2019 | 07:36 AM
Welcome to the forums Lynae,
I've moved your question from General Tech Help to X-Type forum. This is the place to post questions about your model.
Old Nov 8, 2019 | 08:07 AM
TonyJ1977's Avatar
To start things off welcome to the forum. First things first go and have your computer codes ran unless you have your own code reader then post your codes here and someone can or will try to point you in the right path to getting your kitty back to purring. Also do you work on things yourself or do you always have someone else work on things for you ? Doing things yourself saves you allot in repair costs and gets you some one on one time with your cat lol
Old Nov 8, 2019 | 11:09 AM
Thermo's Avatar
Veteran: Navy
Lynae, like was said, when it comes to the motor, get the codes read and then post the info you get. Any local auto parts store should be able to read the codes for you. Sounding like you have a vacuum leak, but, the codes will confirm that.
As for the squeaky brakes. This is normally 1 of 2 things. A simple pad check is going to tell you the difference. If you have lots of pads, odds are the pads are vibrating inside the caliper and this can be solved by getting a tube of "pad glue" (found at your local auto parts store, like $4 for an 8 ounce bottle). You will need to pull the pads out of the caliper and put some of the glue on the back of the pads (the side that touches the caliper). Reassemble and make sure to apply the brakes to squeak out the extra glue. This will stop that squeak. If the pads are worn (ie, under 1/8" of pad, then you need to replace the pads to resolve the squeak.
If you have more questions, please, ask away. You are at the right group to help you keep your kitty purring.
Old Nov 8, 2019 | 11:18 AM
Alfadude's Avatar
You do not have any flashing lights on the dash, do you when the situation happens? If so, do not drive it as it is a misfire bad enough that it will cause damage to your catalytic converter.
Old Nov 9, 2019 | 10:55 PM
Lynae's Avatar
I have flashing engine and it says cruise not available . sometimes the oil light flashes ..
Old Nov 9, 2019 | 10:57 PM
Lynae's Avatar
I am going tomorow to have them read then i will post them . i am scared .
Old Nov 11, 2019 | 05:00 PM
Dell Gailey's Avatar
Try to not drive it. Flashing lights indicate CATASTROPHIC damage can be done in a VERY SHORT amount of time. Short, like in 4-5 blocks in some instances.
Old Jun 29, 2022 | 10:15 PM
micah meyers's Avatar
Default I’m having the same issues please let me know
I’m having the same issues please let me know what you find out I’m just waiting on the radiator to come in before I can really check I have cleaned out my engine I bought my 2003 at an action plz let me know
russ1771
May 10, 2019 07:00 AM
Meouch
Aug 25, 2014 06:57 AM
Disco stu55
Sep 8, 2011 07:12 PM
Platinum Sport
Apr 2, 2011 07:34 AM
