2003 X-Type
Old May 8, 2019 | 04:25 PM
russ1771's Avatar
Default 2003 X-Type
my 03 wont turn over the battery is fully charged, i can jump across the seloinoid and it will turn over but will not start, any ideas ,and i did try putting it in neutral still did nothing
Old May 8, 2019 | 05:24 PM
Welcome to the forums russ1771,
I've moved your question from General Tech Help to X-Type forum. This is the place to post questions about your model.
Old May 8, 2019 | 08:41 PM
Dell Gailey's Avatar
Auto, manual, any lights? Use an OBD and pull codes, look them up in search function in this forum (change search box to "X type only").
When you turn key to position 2 (just before start), does the m.i.l. (engine icon) remain lit or extinguish? Is the PATS light blinking? If so it will blink (after like 30-60 seconds) a series like once, then 3 times or something along those lines?
Old May 8, 2019 | 10:57 PM
dharry078's Avatar
Okay, how about a little history, the genesis of the problem.
My experience compels me to ask, does the message center show anything? Or is it just dashes. It is possible, the PATS lights to extinguish, but check with the message center in the dash, it it displays only dashes,then it wont turn over, it is definitely a CAN issue
Old May 9, 2019 | 07:09 AM
car5car's Avatar
Dealer mechanic told me, instrument clusters die all the time and showed me box of dead clusters. This is what happened to my S.
PATS module is in clusters. If this is your problem, $100 used cluster, $100-150 programming. + towing
Old May 9, 2019 | 02:19 PM
^^ yup a "dealer mechanic" showed you a BOX full of bad clusters!! You'd lie if the truth sounded better.
Old May 10, 2019 | 07:00 AM
RudyF6's Avatar
If a "dealer mechanic" showed you a box of used clusters, the "dealer parts guy" would be all over his *** for the core returns.
If it happened to begin with.
Jim Burke
Jun 16, 2019 03:42 PM
JaguArvid
Feb 26, 2019 01:22 PM
russsmith1771
Feb 26, 2019 10:01 AM
russsmith1771
Feb 24, 2019 09:39 PM
Jose Nahum
Feb 11, 2019 01:14 PM
