Fitting a tow bar
Old Apr 9, 2014 | 11:55 AM
NigelM's Avatar
Default Fitting a tow bar
In the process of fitting a towbar with detachable swan neck and just wondering if there's anywhere in particular that's best to bring the electrical cable into the boot and I can access all wires without to much trouble ,
Old Apr 11, 2014 | 12:36 PM
reyesl's Avatar
Try Topix:
TOPIx - TOPIx
Old Apr 11, 2014 | 01:41 PM
On the boot floor or spare wheel well you will find either grommets or circular metal plugs which can be knocked out and replaced with grommets to give easy access for the wiring harness.
The Parts Catalogue shows two metal sealing plus (item 5) and one each rubber grommet (item 6) and plastic plug (item 7) in the spare wheel well:
Alternatively, you could remove the plastic shield surrounding the boot lock and drill a circular hole through the panel behind it, fitting a grommet to seal it. Once the plastic shield is refitted, the wiring is completely hidden. This is the method used for installing the OE Jaguar towing bar electrics.
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
peterg19
Feb 10, 2023 09:02 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Steve10
Sep 9, 2015 07:54 PM
