Flashing amber warning light
Old Oct 24, 2014 | 09:08 AM
cb4842's Avatar
Default Flashing amber warning light
Hi Guys,
I wonder if anyone has had a similar issue or knows what the issue is.
I went out for a drive this morning and the amber warning light started to flash erratically and intermittently with no message displayed, this continued for about 10 min's then stopped. there was no noticeable fault with the drive of the car. The car had been out about an hour earlier without an issue.
It is a 2004 2.0D SE estate.
Thanks in advance
Craig
Old Oct 24, 2014 | 10:24 AM
dwclapp's Avatar
Craig: Suggestion: Turn the ignition key to the on position to activate all the dash lights and take the picture in the few seconds the lights are on. Circle the amber light in question and post the picture here. Someone will know.
Old Oct 25, 2014 | 09:21 AM
Dr dome's Avatar
Default light
I think he is talking about the amber light above the message center.
Old Oct 25, 2014 | 09:24 AM
cb4842's Avatar
Default Pic added
Yes Dr Dome that's the one I'm referring to, I have circled it in the pic.
Craig
Old Oct 25, 2014 | 10:15 AM
Lcgi's Avatar
Arrow
Hi Craig,
The amber (warning) light you refer to is to indicate to you that the Diesel Particulate Filter (DFP) is full - and requires regeneration.
See that attached;
Hope this helps.
Old Oct 25, 2014 | 12:39 PM
Five Speed's Avatar
Take it for a fast , long run see if you regen & burn the gunge out of the DPF. Make sure you do this once in a while to keep DPF working properly
Old Oct 26, 2014 | 04:19 AM
cb4842's Avatar
Default Thanks Five Speed
There is no message in the display to indicate this and the light was flashing erratically. I will give it a blast though to see if it changes anything.
Craig
Old Mar 26, 2016 | 09:08 AM
G1985's Avatar
Originally Posted by cb4842
Hi Guys,
Thanks in advance
Craig
Well I'm facing the same issue for the last couple of days.Just carried out a code reading,needless to say,there is none.After several ours of investigation I realised that I've seen the amber light flashing last time when the traction control was working a lot in the winter months.Took mine for a spin and when it started to flash the amber light I switched off the traction control and suddenly everything went back to normal.I suspect one of my rear sensors are faulty...
Hope it helped!
Old Apr 5, 2016 | 01:52 PM
G1985's Avatar
Hi Guys,
Thanks in advance
Craig
There's no DPF in our cars...
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
edtexas
Sep 4, 2015 08:20 PM
