Flashing Glow Plugs
Old Mar 2, 2016 | 07:04 AM
newbee's Avatar
Default Flashing Glow Plugs
Hi,
As username suggest i am a newbie!
Just got my x type 2.0 diesel 08 plate, Love it!
On a couple of occasions i have been aggressively accelerating and the glow plugs light has come on flashing amber, loss of power. Pull over restart engine and fine again.
Is this a case of replacing plugs or something else?
Old Mar 5, 2016 | 03:01 AM
twinstacks's Avatar
The flashing glow plug light indicates a fault within the fuel system. Try to get a code reader on it but from past experiences it is usually a drop in common rail fuel pressure but could be many things related to the injection side.
Old Mar 5, 2016 | 08:17 PM
Arthuruk's Avatar
Default flashing glow plug
flashing glow plug light on a 2.0l indicates you are in safe mode (get you home) and from what you say it is most likely a clogged turbo (variable viens get clogged with carbon) common fault with both x type and mk3 Mondeo.
I had the same problem, you can clean the turbo with innotech foam not a hard job just drop the cat.
Old Mar 8, 2016 | 07:59 AM
newbee's Avatar
Hi Arthuruk,
Thanks for the advice, Going to show how green i really am, how do i clean with innotech foam and what do you mean by drop the cat?
Old Mar 8, 2016 | 08:01 AM
newbee's Avatar
Looking at downloading torque pro app and getting a bluetooth reader,, anybody done this and is it any good?
Old Mar 8, 2016 | 01:14 PM
Arthuruk's Avatar
Hi newbee
have a look at innotec website innotec turbo clean.
all you do is lower the catalytic converter to feed it into the turbo
shadow88
Apr 4, 2016 10:21 AM
TexMurphy
Feb 11, 2016 07:13 PM
Muamin
Feb 10, 2016 08:36 AM
kwiksilver
Feb 9, 2016 09:15 AM
shaz
Feb 5, 2016 10:12 AM
