Fluid Capacity
Old Sep 10, 2008 | 03:06 PM
Vanden Plas's Avatar
Default Fluid Capacity
Does anyone know what the fluid capacity for the rear axle and transfer case is on the X-Type 3.0? I was going to use mobil 1 75-140 limited slip fluid. Is that ok?
I will change the tranny fluid later this year. Has anyone confirmed what fliud can be used? If so what type/brand.
Thanks.
Old Sep 10, 2008 | 05:44 PM
Dennis's Avatar
ud
Default RE: Fluid Capacity
I used Royal Purple but M-1 is good too.
TC takes about .65 liters
Rear Diff takes about 1.2 liters
Jury is still out on the Tranny fluid..
Old Sep 13, 2008 | 04:13 PM
Grim001's Avatar
I was told the tranny is 8.5 liters by the dealer
Old Sep 14, 2008 | 07:12 PM
Thanks all!
The job is finished. I drained and pumped out of the transfer case about 325 ml. I added about 450, the max I could before it began to overflow. The drain plug had some sludge on it. The fluid did not look to bad. The rear axle fluid was worse. I pumped out 1.2 L and refilled with 1.4 L until it began to flow out of the plug. The fluid was very, very dark and the plug had more sludge on it. The car drives well with a little less drive line noise. Current miles, 42K.
RaceDiagnostics
Apr 4, 2016 04:00 PM
millertic
Sep 30, 2015 08:11 PM
dmatthewman
Sep 30, 2015 10:10 AM
jjmiah217
Sep 28, 2015 09:09 AM
