Fog-light
Old Jan 28, 2009 | 12:05 AM
91stealthes's Avatar
Default Fog-light
If one's cracked and missing half the lense, would it be covered under warranty? I amassuming not, but wanted your opinion.
If not, where is a good place to purchase? I see them on ebay every once in a while for around $50 USD...is there anywhere cheaper?
I also notice thatit seems there are at least 2different versions of the x-type fog-light...which do I need fora 2005?
Is this easy to replace myself? It is so cold here, Idon't feellike crawling under the car to see if I need to removethe bumper to replace it.
Cheers,
J
Old Jan 28, 2009 | 07:18 AM
Thermo's Avatar
Veteran: Navy
Default RE: Fog-light
stealthes, to remove the fog light lens, you will need to remove the plastic cover on the under side of the bumper cover (requires a T-27 bit for the bolts) and then you will need an 8MM socket to remove 2 screws holding the fog light housing to the bumper cover. Form there you might be able to give the housing a slight twist to free it from the bumper cover or you will need to use a screw driver to release the clip on the one side and then the housing will fall free.
As for which housing, I am not sure which one you would need.
vincent661983
Oct 13, 2012 10:41 PM
CleverName
Apr 26, 2012 07:50 PM
mrtalkradio
XJ40 ( XJ81 )
Oct 23, 2010 10:24 PM
polak
Jan 9, 2009 08:10 AM
