ford engine swap
Old Feb 6, 2015 | 12:33 PM
Sham2004X-type's Avatar
Default ford engine swap
Hi i have a 2004 x-type diesel,after blowing the engine i have swapped it with a ford unit slotted in perfect but it wont start tried everything please if someone has done this can they help me out.
Old Feb 6, 2015 | 01:32 PM
3lvis's Avatar
Did you use your injectors? If yes then make sure they are in the same order as they were in your old engine. If you used injectors from Ford engine then they have to be programmed to your ECU or else it won't start.
I'm guessing it doesn't turn over at all?
Old Feb 7, 2015 | 04:35 AM
Hi Thanks for the reply, Yes have used my own injectors and they are in the correct order but nothing it wont turn over computer shows no fault that should stop it from starting.
Old Feb 7, 2015 | 03:52 PM
3lvis's Avatar
Does the red light near DSC button/gearshifter flash rapidly? Did you use your high pressure pump?
Old Feb 8, 2015 | 10:13 AM
DSC light is not flashing rapidly and yes have used the high pressure pump :/
Old Feb 8, 2015 | 12:05 PM
Alfadude's Avatar
Could the inertia switch have gotten tripped?
Old Feb 8, 2015 | 04:05 PM
Reset the inertia switch but still nothing dosent even make an effort to start have hit a brick wall at this stage
Old Mar 10, 2015 | 03:26 PM
trooper's Avatar
Hi Sham, Did you manage to get your engine running . If not is it turning over.
Wolfy
May 28, 2024 08:06 AM
sogood
Sep 15, 2015 07:35 AM
Foosh
Sep 12, 2015 12:18 PM
bdboyle
Sep 4, 2015 06:16 AM
obwoodie
Sep 3, 2015 07:45 PM
