Front driveshaft oil seal identification
Old Jan 10, 2015 | 11:38 AM
ChrisM's Avatar
Default Front driveshaft oil seal identification
Hello from a new member
I have a 2003 3.0 with a leak from the driveshaft seal / diff seal
I removed the seal and I am trying to identify the part number.....
the Jaguar dealer has one seal showing on the computer - part no C2S4875
I was disappointed to find that this seal is about 1/4 inch larger diameter than the seal I removed
I talked with the parts dept at the dealer and he cannot find an alternative seal in 'the system'
I would appreciate any comments and advice
Old Jan 10, 2015 | 12:24 PM
clyons's Avatar
The current part number appears to be: C2S52519
Old Jan 10, 2015 | 02:14 PM
ChrisM's Avatar
Thank you for your response
I had also found this number but it appears to relate to the rear diff? I cannot find information to confirm the seal number for the front wheel drive diff?
Please could you tell me how you located the number you kindly provided?
Old Jan 10, 2015 | 06:33 PM
clyons's Avatar
I used the Jaguar Electronic Part Catalog (JEPC) that is available at the top of the forum in the FAQ area. Then copied the part number into SNG's web site and did some searching there. Sorry I misunderstood which end of the drive shaft you were looking for.
https://www.jaguarforums.com/forum/s...?highlight=EPC
SNG Barratt - The Ultimate Jaguar Parts Specialist
Also JPLV's web site: 2005 Jaguar X-Type Parts - Direct JPLV Porsche Parts.com
Here's the JEPC for the transfer case. It shows 3 seals. One of them is the one you have.
File Type: pdf
bamforp
Aug 14, 2024 05:36 PM
Dymaxxion
Sep 4, 2015 02:40 PM
bdboyle
Sep 4, 2015 06:16 AM
Jag-o-nomic
Sep 4, 2015 03:07 AM
d a
Sep 3, 2015 02:34 AM
