"Fuse 66" Location
Old Jun 7, 2011 | 10:46 PM
Lbui's Avatar
Default "Fuse 66" Location
Hello folks, I've got a problem with both my electronic seats. Through researching online, I've found that "Fuse 66" is the one I should be interested in. I can't somehow find it however, can anyone help? The vehicle is a 2004 Jaguar X-type 3.0
Old Jun 9, 2011 | 11:03 PM
PreJag's Avatar
That would be under the dashboard on the driver-side kick panel.
Old Jun 10, 2011 | 06:16 AM
Thermo's Avatar
Veteran: Navy
Lbui, you are having an issue because in the middle of 2004, Jaguar changed the wiring harness for the car. In the process, they renumbered the fuse boxes (pre mid 2004 the fuses were number 1 - 89 where later on, each box was numbered one through how ever many fuses were in the box).
Since you are having problems with both seats, you will need to check a few fuses. All of the fuses will be located under the dash in the fuse box there. So, check the following fuses:
Seats with memory settings:
F9 - most likely blown as it takes out both seats at the same time and is battery power
F3 - also high in the list as it takes out both seats at the same time and is the switchable power for the seats
F16 - power to driver's seat only
F3 - power to passenger seat only
Standard 8-way powered seats:
F3 - passenger seat power
F16 - driver's seat power
Hope this gets your seats back up and running. If you need more info, let me know.
Old Jun 12, 2011 | 12:42 AM
Lbui's Avatar
Thanks Thermo! I've taken a look at F3, F9, and F16 all under the driver side. Unfortunately it didn't solve the issue, however I did find a burnt fuse at F3 and replaced it.
Old Jun 12, 2011 | 05:33 AM
Thermo's Avatar
Veteran: Navy
Lbui, do you have the standard 8 way seats or the memory seats? That will help me get you going in the right direction. There's enough differences between the two that having this tidbit of information will get me going in the right direction.
Old Jun 13, 2011 | 08:58 AM
Lbui's Avatar
I have the memory seats, sorry for not stating that earlier.
Rivguy
Nov 13, 2022 02:55 AM
hamilton7550
Jul 30, 2021 11:29 PM
r111ynf
Sep 20, 2015 09:42 AM
eurotire
Sep 18, 2015 07:27 AM
tvholden
Sep 12, 2015 11:13 AM
