Gearbox
Old Feb 20, 2014 | 08:03 AM
sowyers's Avatar
Default Gearbox
Hi,ive had my x-type for about two months now with no problems only now gear selection seems to be a bit hit and miss.
There seems to no problem with the clutch,no slipping etc.
When parked selecting reverse can be difficult but not all the time.
When driving the car gear selection is fine.
I have a 2004 x-type,2.0 petrol.
Old Feb 20, 2014 | 10:01 AM
mbelanger's Avatar
At the risk of asking the obvious...are you sure you are lifting up the reverse lock-out part of the shifter as far as it will go? Failure to do that would likely create issues getting into reverse...
Old Feb 20, 2014 | 12:20 PM
04Xtype's Avatar
This is a common issue. seems to happen more often when it is cold. I usually just go in to first gear and then go in to reverse. First gear is easier to get in to, and then reverse has no issues.
Old Feb 21, 2014 | 10:51 AM
sowyers's Avatar
Many thanks for the replies,i will certainly try the first gear and then reverse.
As far as I am aware I am lifting up the reverse lock-out part of the shifter as far as it will go.
Again many thanks.
JaguarLover101
48
Jun 12, 2023 10:28 AM
3lvis
Oct 1, 2015 01:56 PM
jjmiah217
Sep 28, 2015 09:09 AM
drbill
Sep 28, 2015 12:46 AM
