Gearbox Fault caused by evap leak?
Old Jan 25, 2010 | 09:29 AM
kandA's Avatar
Default Gearbox Fault caused by evap leak?
Hi all!
I recently (about a month ago) had a new tranny installed. Last night as I was driving home, the lovely amber warning light came on and "Gearbox Fault" was reading on the message center. This morning I go to start the car and the message and warning light are gone, but the CEL is still on. So I go to AutoZone and have them read the codes and it only spits out codes related to the small evap leak I have been chasing. The codes are:
P0442
P0456
P1111
Can an evap leak cause the "Gearbox Fault" error?
Thanks!
Old Jan 25, 2010 | 10:59 AM
Brutal's Avatar
No, and those are engine codes(powertrain) they cant interogate the trans module with a generic scanner only engine
Old Jan 25, 2010 | 01:27 PM
85_305's Avatar
my imt o rings are shot, and sometimes my gearbox will come up with that fault in conjunction with the "cruise control unavail" light. They work hand in hand I believe.
Old Feb 13, 2010 | 06:52 PM
ghettomike's Avatar
i read that if you get gearbox fault you need to have the J shifter reset.
found this.
http://www.europeantransmissions.com...XT307-01am.pdf
my gf is getting this warning in her 02 when its on the highway, feels like reduced power apparently...guessing "limp-home mode"
it has only come up when her older bro drives it, she doesnt really drive highway speeds and i maybe drive it once a month.
has anyone fixed this warning properly?
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
