GEm module replaced on X-type Estate 2006 - hatchback malfunction since
Old Nov 27, 2012 | 07:04 AM
Sojanszen's Avatar
Red face GEm module replaced on X-type Estate 2006 - hatchback malfunction since
Hi, I hope someone can help me out, since our Jaguar garage seems to have no clue.
The car has had some alarm failures in the past that have been fixed by Jaguar garage by replacing the Gem module.
Since, we are unable to use the back wiper, window cleaning fluid, and are unable to open the window within the hatchback. My logic sense screams: GEM module is either for a Sedan, or not correctly programmed for an Estate. Garage has looked it up for a few hours without finding the problem. According to the garage, the GEM has no influence on the mentioned problems.
Anyone has an idea? Thank in advance for all your advice!
Old Nov 27, 2012 | 04:48 PM
Thermo's Avatar
Veteran: Navy
Sojanszen, look at my write up in your other posting. That should fix your problem. All of this can stem from a bad "Hatch glass closed" switch. But, I will step you through some checks. If you have more questions, just ask. If in doubt, tell me what checks you did and your results and I will take it from there.
JarodL
Mar 7, 2024 01:39 AM
way2far
Aug 31, 2022 09:26 AM
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
