Getting a little worried here...
Old Jul 21, 2008 | 01:41 PM
rosemont83's Avatar
Default Getting a little worried here...
Hey guys...
So far, I love my X-type. It's a 2002 3.0 liter sport with the 5-Speed manual transmission and has 83,000 miles. The only thing thats beginning to worry me is that sometimes... whether it be a downshift or an upshift..
Old Jul 21, 2008 | 01:42 PM
rosemont83's Avatar
Default RE: Getting a little worried here...
It wont want to go into 4th on the first movement and it feels like it gets stuck at the gate until i put it back to the nuetral position and try again but a little harder. Happened about 3 times since I got the car... Is it normal for the shifter just to get stuck sometimes or is it something I should be concerned about?
Old Jul 21, 2008 | 02:04 PM
rosemont83's Avatar
I have heard that on these cars the flywheel and clutch tend to come loose...
Maybe that is the problem?
rosemont83's Avatar
Sorry for the multiple posts but it only let me post short posts!
Old Jul 21, 2008 | 02:53 PM
KAZsam's Avatar
could also be synchroniser for 3 to 4 shift
Old Jul 21, 2008 | 03:28 PM
rosemont83's Avatar
It also does it from 5 to 4...
Are the gates rubber? Maybe they just got bent from a shift?
And how much would a synchronizer be to replace?
I am unfamiliar with transmission repairs..
Old Jul 21, 2008 | 06:24 PM
Dennis's Avatar
ud
One way to check if it is Syncro's..Is to double clutch...Clutch once to go from 4th to Neutral, then Let out and then push in again to go into 5th..and same dealin down shifting..if the transition is smooth without a hitch, then more than likely it is a syncromesh problems..and thatinvolves removal of the transmission to fix.
Old Jul 22, 2008 | 12:29 PM
rosemont83's Avatar
Ok i tried the double clutching this morning.
Its smoother to go into ANY gear that way.. but not a huge difference.
Old Jul 22, 2008 | 01:31 PM
KAZsam's Avatar
Automatics are usually 3 to 4 thou to repair so for a standard I'm guessing 2 to 3 thou.
Old Jul 22, 2008 | 05:36 PM
flann02x's Avatar
mine does that too it happens on all stick shift cars no worries
Old Jul 22, 2008 | 07:42 PM
Dennis's Avatar
ud
Have the Transmission Gear lube changed to a quality Synthetic..Like Redline or Royal Purple..
Old Jul 23, 2008 | 12:06 PM
rosemont83's Avatar
Alright, Thanks guys! But hey big brother, where is the trans gear lube located? The only fluid I know of for manual transmissions is the brake fluid..
Old Jul 23, 2008 | 01:47 PM
Dennis's Avatar
ud
The drain is on the bottom of the tranny and the fill hole is on the side.
Drain old Lube oil..then reinstall plug
Old Jul 23, 2008 | 01:51 PM
Dennis's Avatar
ud
Then remove Fill Plug and fill to bottom of fill hole with a Lube Oil meeting this spec..WSD-M2C200-C
Old Jul 23, 2008 | 02:42 PM
rosemont83's Avatar
Cool cool.. So do you know about how many bottles of the lube I should get?
Old Jul 23, 2008 | 02:48 PM
Dennis's Avatar
ud
Two aught to be plenty..It say it takes about 1.75 Liters
Old Jul 23, 2008 | 03:15 PM
rosemont83's Avatar
Alright. Thanks again man. Will either do it myself, have my uncle do it, or take it to aamco and let you know how it goes!
Old Jul 23, 2008 | 03:39 PM
Dennis's Avatar
ud
ORIGINAL: rosemont83
This meets the specs..
Old Aug 11, 2008 | 03:23 AM
rosemont83's Avatar
Ok so drained and put about 2 and a half bottlesof royal purple today. It shifts pretty smooth. Only thing is.. got a check engine light about an hour ago. Scanned it and its codes p1384 and p1111. Reset it and light went away. Anyone have any idea whats going on?
