Heater is not working...
Old Jan 26, 2009 | 03:03 PM
Gunz80's Avatar
Default Heater is not working...
hi, guys....
I found that my heater is not working.
well...I had to get back home....so...I drove without using heater for 10mins..
And I tryed..but not working....
When I got home, I opened the hood...the fan was working crazy...and I found that some water(I beileve its coolant)was all over the place.
Can you tell me what's going on???
Old Jan 26, 2009 | 03:18 PM
SpartanX's Avatar
Default RE: Heater is not working...
Yep. You have a coolant leak somewhere. The question is where is the coolant leaking from?
BTW, DO NOT and I mean DO NOT drive the car under any circumstances right now. Figure out where the leak is coming from, and get back to us here.
Seriously, unless you want to crack a head gasket, don't drive anywhere.
Old Jan 26, 2009 | 03:19 PM
BuckMR2's Avatar
Some X types including mine were recalled to have an extra jubilee clip put on the bottom radiator hose...maybe this pipe came off yours?
Old Jan 26, 2009 | 03:56 PM
Gunz80's Avatar
I checked coolant header tank...it was almost empty....wow....
Don't I need to go get some coolant right now?
do you think this happened by bad leaking?
man,......should I go to dealer or anyother mechanics?
I'm in toronto now...do you have any recommadtion?
Old Jan 26, 2009 | 05:06 PM
MarkC's Avatar
Cracks in the expansion tank are a common cause of antifreeze leaks. Yes, you need to refill the system before you look for the leak. If you still have the original coolant, then Dexcool is compatible. Any shop should be capable of this repair.
Old Jan 26, 2009 | 07:37 PM
Real_Tech's Avatar
When you try to top off the coolant make sure it doesn't just pour out on the ground. If the radiator hosehas blown off of the thermostat housing any coolant you add will simply pour on the ground. Make sure this doesn't happen before you try to drive the car. Better to have it towed than to blow the engine.
Old Jan 26, 2009 | 09:50 PM
Gunz80's Avatar
well...I bought a coolant and refilled....then....it seems like I need to fix this leaking problem...I drove my underground grage,,...then..half of tank was gone....again...
Is it expensive to fix it? and how much?
Old Jan 27, 2009 | 04:02 AM
Real_Tech's Avatar
If it is the hose popped off of the t-stat it can usually be fixed simply by reinstalling with a new clamp. I would think a half hour labor including fill and bleed.
Old Jan 27, 2009 | 06:23 AM
SpartanX's Avatar
ORIGINAL: Gunz80
When you were pouring it in, did you look to see where the leak is coming from? If not, then do that first. There's only a few coolant lines, so it should be fairly easy to diagnose.
Old Jan 27, 2009 | 05:38 PM
Gunz80's Avatar
I went to active green to check it....And they said radiator hose is the problem...There was a big hole....
man...This hose was big and attached radiator...It attached too tight (just like breather hose) that is why there was hole..
anyways, they told me that they have to order this part from jag..and it is only comes with completed part...it is $210.
damn....it is too expensive....
do you know where I can get this part in toronto???
jazzman20014
Oct 26, 2015 04:15 PM
xjrjag
Oct 12, 2015 03:16 PM
inactualis
Oct 2, 2015 11:13 AM
dickc
Sep 21, 2015 02:04 PM
