HELP 2004 X-type 2.5 manual P1338 P1637 P1699 Crank no start. Dashes on odometer
Old Aug 20, 2019 | 09:46 AM
Cashthejoe's Avatar
Default HELP 2004 X-type 2.5 manual P1338 P1637 P1699 Crank no start. Dashes on odometer
Please help. My xtype has these codes. Cranks and wont start. I replaces the fuel pump thinking that was the problem. Can an ABS sensor cause all this trouble ? I have ordered a fuel pump driver module and a crankshaft sensor. I really need some advice or the wife is going to make me get rid of it. Please advise.
Old Aug 20, 2019 | 09:56 AM
Cashthejoe's Avatar
Also. Once i replaced the pump. The car sat overnight with batt disconnected. I hooked it up and was able to drive 7 miles. **** the car off and now the dashes are back on the odometer. I have cleaned grounds and checked fuses. I'm sooo confused. Thanks
Old Aug 20, 2019 | 03:16 PM
Dell Gailey's Avatar
First = check the battery voltage, X's are particularly touchy about voltage.
P1338, fuel pump driver module =
Second check the fuse for the pump module =
https://www.justanswer.com/jaguar/36...-2500-rpm.html
P1637 =
P1637 is for the communication between the ECM and TCM
P1699 =
P1699 is a faulty between the ECM and Climate control module
https://www.justanswer.com/jaguar/78...99-direct.html
Last resort =
https://www.jaguarforum.com/showthread.php?t=85596
Old Aug 21, 2019 | 08:12 AM
Cashthejoe's Avatar
Thanks for the insight. I did swap the battery with another. Still no change. I did have it running for a bit. When i shut it off after a 7 mile drive i had the same thing. This car is a trick to figure out. I'll keep trying 😖
Mryates06
Oct 10, 2019 07:30 AM
number1stun
Mar 21, 2016 02:09 PM
ltmax
Feb 22, 2014 07:50 PM
kmg108
Aug 13, 2013 01:56 PM
number1stun
Jul 29, 2010 03:03 AM
