Help figuring out part needed
Old Dec 28, 2014 | 08:06 AM
tonybucks313's Avatar
Default Help figuring out part needed
Took my car to get new fuel pump after install noticed car steering would loose control.. Took to Firestone and when car was lifted we seen damage (Crack in metal bar right above brake line).. Can someone tell me what part is it I need n estimate of repair n if it's worth it... Car runs great new fuel pump n radiator this is the only problem?????? PLEASE HELP
Old Dec 28, 2014 | 03:17 PM
clyons's Avatar
Hard to tell from the area shown in the picture. Perhaps this will help.
Old Dec 28, 2014 | 04:47 PM
Paulc732's Avatar
Looks like the Rear knuckle assembly.
PM Dr Dome I believe he has on from an X he is parting out.
I do know this can be welded as it is not "structural".
Old Dec 29, 2014 | 12:09 PM
astromorg's Avatar
I agree with Paul. A good weld will do, but a replacement wheel knuckle would be better. It may not be 'structural' but if it didn't take any load it wouldn't be there so as a minimum a high quality weld is needed
Old Dec 29, 2014 | 03:08 PM
x_type_lpg's Avatar
looks like this
ebay item 400830589589
major rear suspension component def not Weld able
was it jacked up un this when pump was replaced?.
Old Dec 29, 2014 | 04:35 PM
Paulc732's Avatar
Jag part number is C2s20027
found these with a quick search.https://www.partmyride.com/pg/340169
Old Dec 29, 2014 | 04:57 PM
astromorg's Avatar
Paul, that Part No has been superseded by C2s49745
Old Dec 29, 2014 | 10:35 PM
jagger's Avatar
It looks like your rear trailing arm is completely broken. I am surprised
that the car is even drivable. From the picture it looks like the ABS
wheel sensor cable might be damaged. The emergency brake cable may
be damaged as well.
I can't imagine how that could have happened except for an accident or
driving really fast over really bad roads.
It is unlikely that it could be welded since you would not be able to hold
it in the proper position so as to maintain it original dimensions. I would
try a junk yard.
Pete.
Old Dec 30, 2014 | 01:39 PM
got a fuel pump replaced by a shade tree mechanic im thinking they broke arm tryna lift vehicle.. learned my lesson will only take real shops now
Old Dec 30, 2014 | 01:55 PM
Default Picture
Does this look like correct part
Old Dec 30, 2014 | 08:48 PM
Dr dome's Avatar
Default part
That's the part. I have one if your still in need for it. Pm me we can talk price.
Good luck.
The Dr
TheWarlock
Sep 7, 2015 09:30 PM
danpop
Sep 3, 2015 08:06 PM
MarathonJohn
Sep 3, 2015 07:59 PM
1964Daimler
Aug 31, 2015 06:41 AM
divingmom
Aug 25, 2015 07:54 PM
