HELP!!! x-type keeps rupturing hoses.
Old Aug 24, 2012 | 05:26 PM
konshu's Avatar
Default HELP!!! x-type keeps rupturing hoses.
I just did the r&r on the radiator,but that was preceeded by two hoses in the cooling system rupturing.the radiator cracking was the reason for the r&r. since the radiator r&r a week ago the upper radiator hose has popped off & two more hoses have ruptured.
after the radiator r&r I did the chemical flush & cleaned my resevoir. Why is my car bursting hoses? What should I change?
Old Aug 24, 2012 | 06:07 PM
terry10's Avatar
Hi Konshu your cooling system is obviously pressurizing possibly head gasket failure. Try to get your local workshop to do a sniff test to confirm.
Old Aug 24, 2012 | 08:31 PM
konshu's Avatar
sniff test?
Old Aug 24, 2012 | 10:30 PM
jaglover922's Avatar
Take the expansion tank cap off and see if you can smell combustion in the expansion tank. But I think you will find that when replacing cooling system parts, it's a good idea to do inspection and replacment of hoses as well. I always replace cooling system parts in conjunction with other cooling system repairs even if they aren't bad at the time of the repair. This reason I do that is because I don't want the car to come back the following week with the same symptoms. I've learned my lesson one too many times like that.
Old Aug 25, 2012 | 03:48 AM
+1 to possible Head Gasket.
Another one to check is a stuck Thermostat.
Old Aug 25, 2012 | 04:00 AM
steveinfrance's Avatar
Could it be something as simple as the pressure relief valve in the tank cap?
Old Aug 25, 2012 | 07:56 AM
konshu's Avatar
hoping for the cause to be the cap because the leak wasn't apparent until I put the cap on. meaning thats when it forced the coolant out.
Old Aug 25, 2012 | 12:20 PM
terry10's Avatar
The sniff test is done with a tool that you put a reactive liquid in, run motor up to temp carefully remove expansion cap with a cloth to avoid getting burned, then the tool gets pushed into expansion tank neck and the top of the tool is squeezed to draw off gas and steam, if combustion gas is present liquid changes from blue to green or yellow.
look at this clip
Old Aug 26, 2012 | 09:59 AM
konshu's Avatar
oh ok. thanks Terry.
Paora
Feb 4, 2021 12:36 AM
Msteiner
May 16, 2016 12:19 AM
jospolice
Oct 2, 2015 07:16 PM
millertic
Sep 30, 2015 08:11 PM
