Hi, errors code
Old Oct 28, 2019 | 08:15 PM
JanBratuha's Avatar
Default Hi, errors code
Hello, I checked the Dtc errors and got the following errors. CAN and ECM errors are scary. What to check? Thank you in advance. Jaguar X-Type 3.0 4wd 2001
U1900
U2510
B1318
B1205
B1205
B2627
U2511
B1359
Old Oct 28, 2019 | 10:37 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...-codes-139972/
Old Oct 29, 2019 | 02:06 AM
JagV8's Avatar
They may be garbage. What tool read them?
Old Oct 29, 2019 | 05:25 AM
Thermo's Avatar
Veteran: Navy
jan, based on the numbers that you pulled, looks like you obtained the info by pulling the numbers from the instrument cluster. Get the codes read via the OBD port under the steering wheel. A lot of what is in your list is common things that every X-type has and is probably going to toss you off of the path to figuring out what is actually wrong with your car.
Old Oct 30, 2019 | 06:43 AM
JagV8's Avatar
If they're from the cluster (via ETM), they are garbage. Definitely ignore them.
Old Oct 30, 2019 | 07:07 AM
JanBratuha's Avatar
Default Errors
[font][font][QUOTE = Thermo; 2146551] jan, основываясь на числах, которые вы вытащили, выглядит так, как будто вы получили информацию, потянув цифры из комбинации приборов. [/font][font]Получить коды, прочитанные через порт OBD под рулем. [/font][font]Многое из того, что есть в вашем списке, является обычным явлением, которое есть у каждого типа X и, вероятно, отбросит вас с пути выяснения того, что на самом деле не так с вашей машиной. [/ QUOTE][/font][/font]
I got them using the diagnostic connector under the steering wheel. It’s just that my air conditioning and stove do not work, as indicated by error u1900
Old Oct 30, 2019 | 04:49 PM
Thermo's Avatar
Veteran: Navy
Jan, I am going to break down the codes that you say that you are getting.
U1900 - CAN bus error relating to the ABS System
U2510 - PATS mismatch between the key and the ECM
B1318 - Battery voltage out of range: 9 V – 16 V as seen by the headlight leveling computer
B1205 - Trip computer switch circuit fault
B2627 - Fuel level sensor 2 circuit fault (open circuit fault)
U2511 - PATS ECM invalid data
B1359 - Ignition switched voltage fault
Based on these fault codes, you have quite a few issues going on. I can summarize things down to 3 problems. You have a bad ECM or someone just recently changed the ECM (if the car starts, then we can rule that out), You have a bad PATS module or the wiring between the PATS module and the instrument cluster is failed (if the car starts, then this confirms that both of these are good), and you have a bad turn signal stalk (if you can change the data in the message center, then we can rule that out).
For all of these to happen at the same time, we are either looking at a car that is suffering from being submerged in water and someone pawned the car off on you or someone has been doing a lot of work inside the dash and has caused a lot of problems.
I would say that you need to first try disconnecting the battery and clearing the fault codes. Leave the battery disconnected for about 5 minutes and then reconnect. Take the car out for a 10-15 minute drive and then get the codes read again. Lets see what you still have. Please post this new list. The B2510, B2511, and U1900 are error codes that are created when the car is built and are deleted by the manufacturer before being sent out. But, they get stored in the instrument cluster with no way to be cleared.
One last bit of information that may help get to a resolution, do you control your A/C and heat from the screen on the radio or do you control them from a module above the radio?
Old Oct 30, 2019 | 04:52 PM
And get the codes from an OBD reader, not the stalk codes...
Old Oct 30, 2019 | 05:51 PM
JanBratuha's Avatar
[QUOTE = Thermo; 2147289] Ян, я собираюсь разбить коды, которые вы говорите, что вы получаете.
U1900 - Ошибка шины CAN, связанная с системой ABS.
U2510 - Несоответствие PATS между ключом и ECM.
B1318 - Напряжение аккумуляторной батареи вне диапазона: 9 В - 16 В, как видно из компьютера
системы регулировки фар B1205 - Ошибка цепи переключателя
бортового компьютера B1205 - Отключение неисправность цепи выключателя
ЭБУ B2627 - неисправность цепи датчика уровня топлива 2 (неисправность разомкнутой цепи)
U2511 - неверные данные
блока управления двигателем PATS B1359 - неисправность напряжения зажигания
Основываясь на этих кодах ошибок, у вас довольно много проблем. Я могу суммировать вещи до 3 проблем. У вас плохой ECM или кто-то недавно изменил ECM (если автомобиль запускается, мы можем исключить это), у вас плохой модуль PATS или неисправна проводка между модулем PATS и комбинацией приборов (если автомобиль запускается , то это подтверждает, что оба они хороши), и у вас плохой сигнал поворота (если вы можете изменить данные в центре сообщений, то мы можем исключить это).
Чтобы все это произошло одновременно, мы либо смотрим на машину, которая страдает от погружения в воду, и кто-то заложил вам машину, либо кто-то проделал большую работу внутри приборной панели и вызвал много проблем.
Я бы сказал, что вам нужно сначала попытаться отсоединить аккумулятор и очистить коды неисправностей. Оставьте аккумулятор отключенным на 5 минут, а затем снова подключите. Возьмите машину на 10-15 минут езды, а затем прочитайте коды снова. Давайте посмотрим, что у вас еще есть. Пожалуйста, опубликуйте этот новый список. B2510, B2511 и U1900 - это коды ошибок, которые создаются при сборке автомобиля и удаляются производителем перед отправкой. Но они хранятся в комбинации приборов без возможности очистки.
Последний бит информации, который может помочь получить разрешение, контролируете ли вы свой кондиционер и обогрев с экрана на радио или вы управляете им с модуля над радио? [/ QUOTE]
In addition to the errors I have registered, there are photos of other errors, I also attach photos of the climate control. The car is very bad, probably soon I will dispose of it.
Old Oct 30, 2019 | 06:11 PM
JagV8's Avatar
Fix the P1647 - see other posts.
Old Nov 1, 2019 | 11:22 AM
JanBratuha's Avatar
Default Help
Old Nov 1, 2019 | 03:46 PM
Thermo's Avatar
Veteran: Navy
Jan, based on getting that fault, your can bus connection to the radio (there is an in and an out connection) has an issue. It may be that the plug is just undone or you have damaged the CAN bus wiring. Odds are, you will need to remove the radio and then look at the wiring to hand over hand the wiring and see what damaged wiring you can find. Out of curiousity, have you had any work done on the interior of the car? Of so, I would start in the area that they did the work. That would be the most likely place for the wiring to be damaged.
Old Nov 1, 2019 | 03:49 PM
JanBratuha's Avatar
[font][font][QUOTE = Thermo; 2148212] Ян, из-за этой ошибки возникла проблема с подключением шины CAN к радио (есть вход и выход). [/font][font]Возможно, вилка просто отсоединена или вы повредили проводку шины CAN. [/font][font]Скорее всего, вам нужно будет снять радиоприемник, а затем посмотреть на проводку, чтобы сдать проводку, и посмотреть, какую поврежденную проводку вы можете найти. [/font][font]Из любопытства, была ли у вас работа над салоном автомобиля? [/font][font]Из этого я бы начал в той области, что они сделали работу. [/font][font]Это было бы наиболее вероятным местом для повреждения проводки. [/ QUOTE][/font][/font]
I took off the radio and the wiring in it was not damaged. Radio works, climate control doesn't work!
Old Nov 2, 2019 | 09:00 AM
Thermo's Avatar
Veteran: Navy
Jan, it may not be damaged right there at the radio. it may be damaged where it goes through the firewall, on a support bracket behind the glove box, etc. Granted, it would be something as simple as your radio has failed. It is just a matter of whether you want to do some investigation to find a potentially bad wire or spend money on a used radio to put into the car to see if the radio is the issue. Having a failed radio interupts the communication between the instrument cluster and the ECM which can have downstream effects like the car not wanting to start and data transmission between the ECM and the instrument cluster. But, short of having specialized equipment to diagnose the wiring (like a TDR machine), you are going to either end up taking a guess as to what is failed and go down that path until you can't any more or you will end up having to put some money into the car to have a professional look at it.
Old Nov 2, 2019 | 09:06 AM
JanBratuha's Avatar
[font][font][QUOTE = Thermo; 2148478] Ян, это не может быть повреждено прямо там, на радио. [/font][font]он может быть поврежден, когда он проходит через брандмауэр, на опорном кронштейне за перчаточным ящиком и т.д. Конечно, это было бы что-то же просто, как ваше радио не удалось. [/font][font]Вопрос только в том, хотите ли вы провести какое-то расследование, чтобы найти потенциально плохой провод, или потратить деньги на использованное радио, чтобы вставить его в машину, чтобы узнать, является ли радио проблемой. [/font][font]Неисправность радиопередачи прерывает связь между комбинацией приборов и контроллером ЭСУД, что может иметь последствия в нисходящем направлении, например, автомобиль не хочет запускаться, и передача данных между блоком ECM и комбинацией приборов. [/font][font]Но, если у вас нет специального оборудования для диагностики проводки (например, машины TDR), вам придется либо сделать предположение о том, что не удалось, и идти по этому пути, пока вы не сможете »[/font][/font]
I checked all the fuses. Everywhere. I think the problem is in this block
Old Nov 2, 2019 | 06:36 PM
Thermo's Avatar
Veteran: Navy
Jan, I am curious what makes you say that. Are you seeing damaged wires? Are you seeing connectors that have melted the plastic and are now touching? Are some of your connectors a brown color vice a silver color? This connector is a possibility as it is associated to your climate control system. But, without a smoking gun (bad wire, damaged plug, discolored connectors, etc), this would be a guess as to what is doing on.
If you are sure that this is the source of your problems, then you need to be looking at 4 pins in that connector based on your indications. 2 of the pins will have yellow wires coming out of them. These would be at pins 9 and 22. One of these pins is the communication in, the other is communication out. The other 2 pins are going to have a green wire associated with them. These will be on pins 10 and 23 of the same connector. If all of this looks good, then you most likely have a bad climate control module (its ,part number is the 1X4H number in the picture above. Of note, the last 2 letters of that part number are key. That is the version number that your car has (ie, the "CE"). if at all possible, you want to get that same version. If you can't, get something that is "CX" where X is a letter hopefully close to E.
Old Nov 4, 2019 | 02:13 AM
JanBratuha's Avatar
Default Help
Ok, I'll check everything, but later I just got sick
Old Nov 5, 2019 | 04:12 PM
JanBratuha's Avatar
Default Help
I think this is the correct scheme for this block. Are you sure the CX will do?
Old Nov 6, 2019 | 05:19 AM
Thermo's Avatar
Veteran: Navy
Jan, as long as you are getting a new module that has the same number as your old module except for the last letter, then you should be good. Your current module is a version "CE". If you can find a Version CF, or CG, then you should be good. I am not sure how high they went in the version numbers.
Jaguila
Dec 10, 2014 03:13 AM
ragekage23424
Nov 19, 2013 10:24 AM
Dumb/Luck
Jun 18, 2011 06:29 PM
strawinski
Jun 2, 2010 05:02 PM
perezrp101
Jun 25, 2009 07:13 PM
