High Squeal at cold air temps?
Old Feb 24, 2009 | 10:45 AM
mohrd's Avatar
Originally Posted by TonyX
I found this source for what looks to be reasonable cost for new drive shaft: http://www.trademotion.com/partlocat...layCatalogid=0
Approx'ly $650 for part + $70 for shipping.
Has anyone ordered from this place and can share experience?
Haven't had any experience with these folks but, that is a good price. Unless you are in Canada. Then you've got duty, brokerage fees, etc. You also need the paper gaskets and all new bolts to install it. Are you installing it yourself? Trouble is if you are supplying your own parts to someone else to install, don't look for the work to be warranteed.
Old Feb 24, 2009 | 11:37 AM
TonyX's Avatar
Mohrd,
I appreciate the reply. Do you know the technical reason behind the needing new bolts? It seems to me they are not torqued to yield type(only 20 Nm tightening torque) so why the need?
The JTIS also stated no need for paper gasket if replacing with new prop shaft "otherwise damage to vehicle may occur" What's the reason for this? Why would a paper gasket cause damage if installed with new prop shaft?
Old Feb 25, 2009 | 12:00 AM
mohrd's Avatar
you'll need one of the techs to answer that for you.
02jagstype
23
Oct 23, 2022 07:03 PM
Jandreu
Jun 30, 2022 03:10 PM
tberg
Sep 7, 2015 07:32 AM
1100me
Sep 7, 2015 06:26 AM
Corycarlo
Sep 5, 2015 11:41 AM
