Hood Ornament Replacement
Old Jun 12, 2009 | 07:52 PM
mrcjr24's Avatar
Default Hood Ornament Replacement
Is there a special way to remove the mount that the leaping jaguar is on? I just bought a new leaping jaguar but I can't remove the old mount? 03 x-type
Old Jun 13, 2009 | 05:11 AM
JOsworth's Avatar
search "leaper" in the S Type pages. There are a couple posts that talk about it. Basically it is like pulling an emblem off, remove the nut, use fishing line or something similar to cut through the adhesive, then work on getting the remaining adhesive off.
Old Jun 15, 2009 | 01:00 AM
mohrd's Avatar
You didn't specify why you can't remove the base.
There is a single vinyl nut the you access through a hole in the underside, another peg to help orient it and then IF it was adhered as well (my '02 wasn't) use the doubled up dental floss or thin fishing line to method to get it unstuck.
Old Jun 23, 2009 | 10:43 AM
mrcjr24's Avatar
thanks the dental floss method worked just fine...
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
