How to fix annoying Brake/J gate Clicking Noise
Old Jan 23, 2014 | 02:37 AM
Poundy's Avatar
Default How to fix annoying Brake/J gate Clicking Noise
I see this problem still seems to crop up a lot on the forum. I am pasting a link from our jaguarforum uk brothers, that I found that enabled a cheap fix to the problem. Easy to follow instruction and Photo's, I am sure they will be glad we took advantage of it. I did mine no problems since, good luck may make a useful DIY Sticky.
https://www.google.com.au/url?sa=t&r...59568121,d.dGI
Old Jan 23, 2014 | 09:12 AM
flyrr100's Avatar
You know, mine's been doing it for so long I forgot it clicked!
Old May 25, 2017 | 01:01 PM
gotbeef's Avatar
I recently bought a X type 3.0 with the same problem.
How I fixed it:
Carefully pry open the original microswitch and LIGHTLY sand the contact surfaces by putting a small strip of thin sand paper and then pulling it out. You can put a VERY thin layer of conductive anti corrosion grease (copper grease) to help with operation as well. What's happening here is that the contacts that make a complete circuit when the car is out of P and R can arc during opening and closing and this arc creates a layer of oxides that prevent the contacts from conducting electricity.
No money spent and no cutting/soldering wires!!
trosty
26
Dec 18, 2022 06:40 PM
flyrr100
Mar 14, 2016 06:37 AM
raulan
Sep 10, 2015 12:43 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
jaguarbill
Sep 5, 2015 11:43 AM
