How to get drain plug off transfer case?
Old Aug 1, 2012 | 11:02 AM
steuey67's Avatar
Default How to get drain plug off transfer case?
I am trying to drain and fill the transfer case on an 03 x type. I have read a few threads on the topic; however, I can't get the plug out. I can't find a 3/8" square allen wrench anywhere and there is no way to get a square drive that fits into a ratchet in that tight space. If anyone has drained their transfer case, please help.
Old Aug 1, 2012 | 11:31 AM
Thermo's Avatar
Veteran: Navy
steuey67, what a lot of us use is an extension that has the flex joint at the very end. From there, you can stick it in and it will back right out. Your other option is if you can find a 3/8" square barstock, you can stick that in the plug and then use a wrench on the other end to break the plug loose. From there, you should be able to spin it out by hand.
Old Aug 2, 2012 | 04:13 AM
Green Machine's Avatar
Wink
I use a 1/4" socket driver with a 3/8" adapter on mine.
silkcat
Jan 18, 2025 04:29 AM
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
chatmanx
Sep 11, 2015 07:17 PM
