how to remove and clean egr valve
Old May 31, 2012 | 05:40 PM
jonesy1974xtype's Avatar
Default how to remove and clean egr valve
I've an x type 2.2 d sport. I put my foot down today and lost a bit of power top end then my coil light started flashing. I got home without any issues other than the flashing and took it easy. When i got home and switched off the engine. Then i held down the trip button and turned the key to position II. no error codes. No flashing coil light.
A bit of research on the net seemed to suggest the egr valve is dirty and sticking.
my x-type 2.2d estate (56 plate) has an intermittent fault, - JustAnswer
Here is a link on how to remove it and clean it rather than buy and fit a new one.
JX EGR Cleaning.pdf -- June 3, 2011 8:58 pm -- 167k
Old May 31, 2012 | 08:19 PM
Thermo's Avatar
Veteran: Navy
Once you get the EGR off, use some carb cleaner and spray it really good. Keep spraying until the fluid runs clear. Reinstall the EGR and call it good.
Old Oct 29, 2015 | 06:14 AM
talzed's Avatar
hi mate, its probably not the egr valve. i had the same problem for ages its a sticking turbo, watch this video i did this and it works a treat,
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
Corycarlo
Sep 5, 2015 11:41 AM
XFR_Gold
Sep 2, 2015 12:24 PM
