Hub nut
just short question if i may, What size is the Hub nut (mm) so i can order a socket to fit please. Its also know as the Axle nut , Drive shaft nut possibley more names.
Its not the wheel nuts thanks the hub nut that goes on the end of the drive shaft and hold the bearing , hub and drive shaft to the car.
Also is it ment to be a nut with a collapsible edge or a locking washer thing or just alot for force to stop it undoing itself.
It's 32mm. Just an FYI, unless you have a [good] air impact gun, you're going to find it's next to impossible to remove. I attempted it by hand before failing and using that as an excuse to finally get a compressor and air tools.
However, 32mm as stated by spielnicht - sounds right for the Hub Nut.
(dunno about the economics of his rattle-gun though)
Have a nice day.....
I think the guy i brought the car from 1.5 months ago has put new bearing on and did NOT do the nut up tight enough.
The problem im going to have is making 200+ nm of torque to do the new one up with out air tools.
only joking thanks for the help
Nope, I'm not at all sold on the rattle-gun approach.
Good luck with it anyways....
