humming noise at 30mph
Old Oct 4, 2009 | 06:52 AM
Thermo's Avatar
Veteran: Navy
Pete, check your carrier bearing for the rear drive shaft. When the bearing gets a little dry, it will tend to make a hum. Get a needle valve, squirt some grease into the bearing and see if that helps. After that, how is the fluid level inside your transfer case?
JimC64
31
May 30, 2016 03:04 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
ChrisJay
Sep 27, 2015 09:08 AM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
