IDS programming options...
Old Apr 19, 2008 | 08:51 AM
BuckMR2's Avatar
Default IDS programming options...
Took my car to a LandRover dealer this morning who said he would try and eliminate the PECUerror on my speedo since upgrading to premium sound as he has an IDS machine and offered to try anddo it for free.
On the IDS machines there are 2 options for further menus for enabling Premium Sound.
One option is Premium Sound (which he went into and enabled the CD etc) the other is option isPremium Sound (audiophile) which he didnt know about and he was reluctant to go into incase it damaged any other ECUs/management boxesin the car.
What is the difference with the audiophile option?
Old Apr 19, 2008 | 09:03 AM
jag_genius's Avatar
Default RE: IDS programming options...
audiophile usually means the highest sounds system that every came out in the car.. i believe x's in northamerica just cam with premium sound as there highest .
Old Apr 19, 2008 | 11:01 AM
BuckMR2's Avatar
As far as I know Premium was the best sound system in a factory X Type in the UK too even so the IDS machines have this as a menu so there must be a different reason??
Old Apr 19, 2008 | 12:50 PM
jag_genius's Avatar
then ids is wrong.. as usual.. the cd the engineers.. give us they always mess something up.. as soon as we get a new disc load it.. then there is updates.. stuff they mix up or mess up. did you get it to program? and everything works?
Old Apr 19, 2008 | 03:23 PM
FactoryJaguarTech's Avatar
NAS cars have audiophile if they have seperate amp. Base is just crap speakers run from audio unit. Premium is upgraded but still running from audio unit. Audiophile has seperate amp and sub. I always programme as audiophile on vehicles with amp and subs and never had a problem.
Old Apr 20, 2008 | 07:16 AM
BuckMR2's Avatar
What is NAS? Is it North American vehicles?
Re the programming
PECU error has been displayed since adding amp.However everything works as before 90% of the time, sometimes the sound goes off and whatever radion station on preset 1 is displayed also cant select CD from the headunit.Turning the ignition off and back on normally restores things.
It seems to forget what has been programmed and reverts back to non-premium and no CD changer each time it has subsequently been hooked up to an IDS.Even though amp and CD as said works 90% off the time and it has had a CD changer from factory when new.
Maybe programming with audiophile will be the answer as it is a 2002 car but has the 2004- premium system with seperate amp to bass.
Old Apr 20, 2008 | 04:08 PM
jag_genius's Avatar
i guess in canada we dont have audiophile.. only have preimum.. for the x's
Old Apr 20, 2008 | 04:16 PM
For anyone that has access to the wiring diagrams for these cars:
Look at say a X-Type wiring diagram. ICE. Standard shows like 4 speakers from audio. Then premium shows 8 speakers and subs....still from audio.
Then look at say 2005 XJ - doesnt show standard. But shows premium - 8 speakers running from audio unit, no amp and no subs. Then next page is premium (audiophile) with 10 speakers and 2 subs....all running from the amp.
I had to explain this to one of our old timers who said none of our cars were audiophile. He would programme as premium and they would always come back....lol
Basically....if the car has seperate Amp.....it is Audiophile.
Old Apr 21, 2008 | 04:01 PM
BuckMR2's Avatar
I am going to try and get my car back into the LandRover specialist this weekend and get him to use the audiophile menus/options to see if it sorts it
Thanks all.
Old Apr 27, 2008 | 04:17 AM
BuckMR2's Avatar
Had the specialist try to program the amp/headunit using premium audiophile options but it keptreverting to premium and PECU ERR error still there (wonder if this is because its a 2002 car (which would have premium if fitted) with a 2004- premium upgrade (which would have premium audiophile if fitted) ??).
They suspect amp or wiring so I am going to try and source another amp.
Old Apr 27, 2008 | 10:30 AM
jag_genius's Avatar
i finally saw last week a x type with audiphile separate amp.. kinda rare in canada..
Old Apr 27, 2008 | 10:58 AM
For what it is worth, bestbet is to cut into the harness and wire all speakers into a seperate aftermarket amp. Much cleaner sound....oh and don't forget aftermarket speakers too!!
Marka
22
Sep 11, 2016 12:09 AM
redxk8
Sep 30, 2015 08:18 AM
Jzar
Sep 27, 2015 02:55 PM
zdrapec
Sep 25, 2015 05:49 AM
