Ignition Switch/Key Won't Turn
Old May 24, 2012 | 07:12 PM
BLAKE518's Avatar
Default Ignition Switch/Key Won't Turn
HELP.... I have an '03 X-Type. Suddenly when I try to turn the key to start the car the key will only turn slightly, not even as far ACC. I have to keep turning the key off then towards start repeatedly. Sometimes it will turn by the third time and sometimes it takes as long as 10 to 15 minutes to get the key to finally turn to start the engine. Is this a common issue? Is there something I can do to fix it myself? Should I be worried about the key eventually not turning at all? THANK YOU!!
Old May 30, 2012 | 02:42 PM
disguay's Avatar
Is your key worn down at all? It seems to me like your key got so worn down that the car doesn't recognize that the key in the ignition is the same key to start the car. I have noticed that my key is very worn down and was actually worried about a problem like this happening with a old worn down key. The jaguar ignition is not to kind on keeping keys in perfect condition either. It's like sandpaper in there :/
Old Apr 5, 2013 | 03:28 PM
95Jagxj6's Avatar
I had a similar issue where the key would turn somewhat, but not into start position. It turns out the steering wheel was locked. I jiggled the steering column while pushing the key forward, and it started as soon as the steering wheel came unlocked. Your issue could be a worn key, or worn tumblers in the ignition chamber, but checking the steering column is worth a try.
Old Apr 5, 2013 | 03:32 PM
Brutal's Avatar
Replace the worn key and the lock barrel. Not just the key. It eventually will not turn and have to be drilled out to replace. Yes its common as in ive done a handfull. Dont wait its gets more expensive and you will be stuck somewhere when you least need it to happen. Like when someone is chasing you with a chainsaw
Old Apr 6, 2013 | 12:35 AM
billbjork's Avatar
Say 95jagxj6't
I can't count the times I've been summoned to the garage for a "I can't turn the key" and it was the steering lock, I give up showing them,just go do it,
Old Apr 7, 2013 | 11:55 PM
disguay's Avatar
billbjork, people think I am magical when I get called across town cause someones car won't start due to the steering wheel being locked.... at least its worth free lunch
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
jagent
Sep 12, 2015 01:40 AM
avern1
Sep 8, 2015 06:25 PM
