installing ac compressor, couple quesitons please
Old May 19, 2010 | 08:14 PM
matl's Avatar
Default installing ac compressor, couple quesitons please
Hi i will be putting in a salvage A/C compressor this weekend and i'm unsure about a couple things. First off when draining the existing system do i just release it into the atmosphere or is it freeon and i should handle it differently? Also im sure theres a proper way to release the tension on the belt but i have no clue how, can someone point me in the right direction? Thanks!
Old May 19, 2010 | 10:02 PM
Brutal's Avatar
have the freon sucked out by a shop, dont F^^&)up our environment more than already. to release the tension use a 3/8" drive long ratchet to rotate the tensioner pulley to the left and slip the belt off only the compressor
Old May 19, 2010 | 11:38 PM
matl's Avatar
Cool, thanks for the heads up. I'll do it right, dont want to be irresponsible about it.
Old May 25, 2010 | 07:29 PM
matl's Avatar
Can anyone tell me what kind of compressor oil the x-type needs? Per my local shot it take 5oz but they dont know what kind. They also told me itll take 28oz of refrigerant, sound correct? thanks
Old May 25, 2010 | 09:02 PM
Thermo's Avatar
Veteran: Navy
Matl, I don't know the type of oil that is used in the car, but most of the R-134a that you will find, will have the oil pre-mixed in. So, there is no need to add oil to freon that already has it in it. The JTIS simply calls it "refrigerant oil". As long as the oil is compatible with R-134a, it will be fine for your system.
As for the amount of freon, 28 ounces sounds around right. The 5 ounces of oil is also correct.
Old May 25, 2010 | 11:38 PM
matl's Avatar
Ok great, thank you for the response. I will try and go that route.
trosty
26
Dec 18, 2022 06:40 PM
kevinl
Oct 31, 2019 06:15 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Corycarlo
Sep 5, 2015 11:41 AM
d a
Sep 3, 2015 02:34 AM
