Jack stands
Old Feb 4, 2010 | 07:04 PM
compdude97's Avatar
Default Jack stands
Ok I am going to be doing my first oil change on my x this weekend, weather permitting. And I have yet to jack the car up, where are the jacking points, and where should I put my stands once the car is up?
Old Feb 4, 2010 | 07:43 PM
Thermo's Avatar
Veteran: Navy
compdude, I jack up my car under the front edge of the door. I place the jack on the frame where the two pieces of metal are welded together and then I put the jackstand on the frame just in front of the jack. For the rear, I put the jack as far back as possible on the frame and then place the jackstand in front of the jack there on the frame.
if you come back about half way on the front doors and put the jack on the frame there, you can lift up the whole side of the car and then position your jack stands where you want from there.
Old Feb 4, 2010 | 08:31 PM
Green Machine's Avatar
Cool
I use ramps, but because the car is so low, I use about a 2 foot long 2 X 6 laid low on the ramp about 6 inches from the lower end, which allows the facia to clear the ramps.
Old Feb 4, 2010 | 09:11 PM
Jaggyx's Avatar
same as thermo for me
SD96XJ6L
Dec 27, 2025 09:58 PM
Johnken
Apr 8, 2018 10:21 AM
Dave1109971
Dec 15, 2015 06:16 PM
NathanDD6
Oct 6, 2015 11:20 AM
dmatthewman
Sep 30, 2015 10:10 AM
