Jacking up car for transfer case fluid change.
Old Mar 17, 2015 | 10:04 PM
Lubrication's Avatar
Default Jacking up car for transfer case fluid change.
I have two good floor jacks with a MAX lift height of 19.3 inches. I am going to drain the transfer case oil when the car is level, then lift one side to get that 400ml top-off in there. I know Jag says it needs to go up to 21.25 inches from the lower lip of the sill.
My question is, can I top off properly from perhaps 18 inches of lift (from the jack point)? I don't want to buy more jacks, and I'd like to NOT push the lift height to max or add unsafe stuff to the mix.
Thank you!
Old Mar 17, 2015 | 11:19 PM
Oh, Hell with it. Look what I found!
Amazon.com: Powerbuilt 640912 All-In-One 3-Ton Bottle Jack with Jack Stand: Automotive Amazon.com: Powerbuilt 640912 All-In-One 3-Ton Bottle Jack with Jack Stand: Automotive
I was thinking I'd need to spend $500 in floor jacks, but these are nearly free!
Combined with my jack stands, I should have quite a solid lift.
Old Mar 18, 2015 | 07:34 AM
Steve M's Avatar
Do you have the post on how to do this job?
Old Mar 18, 2015 | 01:03 PM
Alfadude's Avatar
Steve, look up at the top of the X-Type forum page in the Sticky section under "How To". That is liste din there along with a bunch of other useful information.
Old Mar 20, 2015 | 04:57 AM
ugotmale's Avatar
If you need some extra height use like a 2x6 or 2x8, how ever big the base is, square of wood to set the stand on.
Old Mar 21, 2015 | 12:49 AM
Another silly question.
Doesn't lifting like this (still waiting for my equipment, so I haven't done it yet) cause massive stress to the wheels on the other side? Seems like it would put an extreme load on them, possibly doing a slight amount of damage.
Old Mar 21, 2015 | 06:48 AM
3lvis's Avatar
It won't cause any damage as you can easily put suspension under a lot more stress while driving.
BrentGardner
29
Dec 16, 2024 12:13 AM
Rupesh
Mar 25, 2016 03:33 PM
bigpav7
Sep 7, 2015 01:37 AM
1964Daimler
Aug 31, 2015 06:37 AM
mrplow58
Aug 29, 2015 10:44 PM
