here i start with all my problems small and big with my carif anyone has any ideea please help 1 - o2 sensor P1646 code well i have the part but is a pain in the...to change the sensor...no room 2 - abs sensor c1175 wheel speed rear left sensor (i change the sensor and keeps coming up 3 - i changed the rear break pads as i had nothing left on them and the rear left wheel still has a noise like something is touching the disk...i will check tomorrow again everything i hope is not the wheel bearing and is just a jammed caliper witch is a easy fix 4 - rust...my god this cars rust as we sit and speak...i will show you pictures tomorrow before and after welding.... 5 - lights right high beam and fog lights don`t work anymore changed all the bulbs with LED ones change and check all fuses and relays ...also i need to take down the front end of the car and repair both headlamps i have the kit to fix the levelling as now they are allover 6 - left mirror squeaks when i fold it ..i sprayed a good amount of graphite penetration oil...but still has the sound i need to fix it ..it kills me...
7- front/rear suspension i need to changed everything...shocks absorbers i need to buy but i have springs (i have some lowering springs) also i have all the bits and bobs..to clear my stress called knocking = new track rods, new ball joints, new anti sway links pain in the *** to change as all bolts are rusted
8 - i just changed the windshield (160£)
9- i need to buy 4 rims on 18 or 19 and some tires for summer and to change the tires on the standard with some winter tyres
