Jag 2000 wheels fit '04 x type. Also tire question
Old Dec 30, 2012 | 10:40 AM
eriklane's Avatar
Default Jag 2000 wheels fit '04 x type. Also tire question
Saw some used wheels off a '2000 jag', that's all the person knows. Got them from cleaning out an apartment basement.
Will they fit an '04 x type? These wheels are 5 bolt, obv...
ALso, my jag has 225/50/17. What is the smallest tire I can use as a replacement? Trying to save some $
Old Dec 31, 2012 | 05:11 AM
Aonsaithya's Avatar
Ask for a photo, someone may recognize them.
In a day or two, when I get my PC finished, I can compare the photo with the Jaguar Electronic Parts Catalogue and 95% likely find the name and specs.
All recent Jag wheels are 5 bolt, but some are 5x108 and some 5x120. S-Type and X-Type are the same aside from offset and S-Type wheels being generally wider so you might need spacers with those. XJ and XK wheels are way wider.
Old Dec 31, 2012 | 09:48 AM
eriklane's Avatar
http://i306.photobucket.com/albums/n...psad03701c.jpg
Wondering also if Taurus wheels would work.
Old Dec 31, 2012 | 03:37 PM
Aonsaithya's Avatar
That isn't an X-Type wheel, but can't be more specific without the catalogue.
Old Dec 31, 2012 | 08:36 PM
eriklane's Avatar
Looks like Taurus and X type wheels are the same. 4.25" (measure from 2 lug holes, their bottom to the middle of the hole immediately across the wheel). 108Mm. High positive offset.
I'm going to check my daughter's taurus wheel tomorrow on the Jag and then if it fits, I found 4 taurus wheels with snows...
Old Dec 31, 2012 | 09:00 PM
Thermo's Avatar
Veteran: Navy
Erik, see if you can test fit a wheel to make sure that it would work on your car. As for Ford Taurus wheels working, atleast the 2002 or so years will work. They use the same bolt pattern and the spacing of the rims is pretty close.
Old Jan 2, 2013 | 03:09 AM
Aonsaithya's Avatar
Hmh, I didn't find those wheels from the catalogue.
X-Type offset is positive 52.5mm as far as I know.
Old Jan 2, 2013 | 09:20 PM
eriklane's Avatar
Turns out that 2006 Taurus wheels do exactly fit my 2004 X type...
MJ'S Jag
Nov 10, 2022 08:14 AM
rvdz
Dec 7, 2019 06:42 AM
h4wk
Nov 27, 2015 05:10 PM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
