Jaguar Technician Information System (JTIS) download
Old May 11, 2013 | 08:03 AM
  #161
Thanks Jim, if you need any help let me know.
Old Jun 28, 2013 | 03:43 PM
  #162
SteveSheldon's Avatar
Just to let you know.. I run Linux here - but with Wine, and downloading it from http://www.cannell.co.uk/Jaguar_Work...uals/JCD-1.zip
It worked straight away after unzipping and running setup.. If I can get it to run in Linux it should definately be Ok for Windows users :-)
Now I just need to get used to its format..
Many many thanks for this
Old Jul 23, 2013 | 10:42 AM
  #163
tonyvisone's Avatar
this downloaded fine for me, and i can open the program, but as soon as i click one of the buttons it closes the program.
upon install it mentioned clicking the disk 1 setup yet still finished installing. if i try clicking that file it doesnt work and talks about 32 bit vs 64 bit. i tried the compatibility mode and it did not work either.
Old Jul 23, 2013 | 12:07 PM
  #164
jimlombardi's Avatar
Update: Solution to your internet browers invalid link errors (getting "This link wasn't well formed") when trying open the dropbox.com using the PDF weblinks I have in this post.
Looks like I had a bad upload to the dropbox.com website (PDF file for JTIS21 install on 32 bit Windows Operating systems (Windows 8, Windows 7, XP, and Vista)
I fixed the issue by reuploading the PDF file.
If you ever get the "This link wasn't well formed" - invalid link error, then you should look at the solution I found on the internet that is in the following PDF file:
https://www.jaguarforums.com/forum/a...che-issues-pdf
End of Update
Here is what you need to know before you download and install the JTIS21 software
First you need to determine whether your PC has a 32 bit or 64 bit Operating System.
Method to determine Windows XP 32 bit or 64 bit
Look at this JPEG (has instructions/illustrations) Click on the image when the dropbox webpage to get a better view:
https://www.dropbox.com/s/0zo00wh83i...20bit%20OS.jpg
Method to determine Windows 7 (32 bit or 64 bit Operating System):
https://www.dropbox.com/s/khcyplnz98...20bit%20OS.jpg
This PDF covers install on a 64 bit Windows 7 Operating System (also the other windows 64 bit OS - Windows 8, XP, and Vista):
https://www.dropbox.com/s/fe6jkw5py3...bit%20v1.6.pdf
If you have windows 8 64 bit you may have to download the microsoft 32 bit help software for windows 8
https://www.dropbox.com/s/0wtvz3ux3s...917607-x64.msu
PDF file for JTIS21 install on 32 bit Windows Operating systems (Windows 8, Windows 7, XP, and Vista):
https://www.dropbox.com/s/j6wjvc5esl...%20systems.pdf
I put the JTIS archive files up on my dropbox account. I have had no problems with the downloads on the dropbox.com site.
When the dropbox webpage opens, just click on the download button and use the run option on the popup.
Here are the weblinks to the all models (JTIS21) archives files.
Part1.exe is 190 mb (195313 kb)
https://www.dropbox.com/s/fvdg6rsl63...CD.part1.exe?m
Part2.rar is 190 mb (195313 kb)
https://www.dropbox.com/s/bwx4uch8m9...CD.part2.rar?m
Part3.rar is 58.9 mb (60318 kb)
https://www.dropbox.com/s/xk49mq38ch...CD.part3.rar?m
Decide where to place the JTIS files after they are extracted (CD or on PC hard drive).
This PDF describes both the CD and Hard drive processes:
https://www.dropbox.com/s/dt47u5qcx5...structions.pdf
Jim Lombardi
Old Jul 25, 2013 | 09:06 AM
  #165
tonyvisone's Avatar
Jim,
this looks like phenominal help, but none of the links work
Old Jul 25, 2013 | 09:09 AM
  #166
tonyvisone's Avatar
i have vista 64 bit however......
Old Jul 25, 2013 | 12:29 PM
  #167
Hi Tony
Apparently some of the PC(s) have a DNS memory Cache issue that is causing the Invalid file format you are experiencing when you try to use the weblinks in my post (post# 164).
I updated post# 164 just now with instructions on how to clear the DNS memory Cache issue.
Go to post 164 for the instructions on how to clear the DNS memory Cache and then all the weblinks will work properly.
Jim Lombardi
Old Jul 27, 2013 | 06:10 AM
  #168
RoonieQ's Avatar
Great stuff here Jim. Thank you.
I see in the links that the pdf describing installation on 64bit systems is not actually a pdf file but a jpg. I think the link is referencing the wrong info.
Old Jul 27, 2013 | 08:28 AM
  #169
My error, Thank you
I am getting a little punchy, I had to post this Great stuff in 8 different threads.
I corrected the weblink.
Please test all the links in the post# 164 for me.
Jim Lombardi
Old Sep 1, 2013 | 08:48 PM
  #170
rogers1511's Avatar
Anyone have the JTIS for the 2007 XKR??
Old Sep 2, 2013 | 01:18 AM
  #171
BuckMR2's Avatar
Last JTIS was 2005 after that it switched to online subscription via TOPIX
Old Sep 3, 2013 | 08:44 AM
  #172
Looks like jagdocs.com sells the workshop manual PDF file download for 2006 thru 2009 XK8/XKR model X150 for $11.39.
http://www.jagdocs.com/index.php?mai...roducts_id=234
I am not sure how it was created (maybe from TOPIX????)
Jim Lombardi
Old Feb 21, 2015 | 06:15 PM
  #173
XK8Troll's Avatar
Anyone know how I can get JTIS info for 1999 XK8? I have tried all the different links, and they lead from one commercial operation to another, all with subscription charges, without ever referring to the JTIS information. Is there anywhere I can just download the info, instead of getting an account that is says will download any info I want, but then they don't work, and nothing can be downloaded?
Old Feb 21, 2015 | 06:34 PM
  #174
Here is the link to jagdocs.com - 1999 XK8 & XKR workshop PDF download ($11.24):
http://www.jagdocs.com/index.php?mai...roducts_id=451
Jim Lombardi
Old Feb 21, 2015 | 08:34 PM
  #175
clyons's Avatar
From the large file area - http://www.mediafire.com/view/ldfaed...ed_in_1999.pdf
Old Oct 24, 2015 | 04:38 AM
  #176
George Kirov's Avatar
Hi there,
this is my Jag:
Jaguar X-type
Any opinion much appreciated!
Kind regards,
George
Old Oct 24, 2015 | 09:36 AM
  #177
Alfadude's Avatar
Not quite sure what your question is.
If you are having an issue you might want to start a new thread instead of attaching it onto the JTIS sticky. That was you are more likely to get timely responses
Old Feb 14, 2016 | 10:59 AM
  #178
jbd's Avatar
jbd
Hello I'm looking for a JTIS for my XK8RS 2005, can you help please?
Best wishes
ps I have found lots of useful info on this site so far, well done all.
Old Feb 14, 2016 | 01:15 PM
  #179
Alfadude's Avatar
Welcome to the forums. This is the X TYPE section. You will have better luck if you check in the XK section. Someone in that forum might be able to help you.
Old Feb 15, 2016 | 05:12 AM
  #180
jbd's Avatar
jbd
Thanks will do. From your username I take it you have some interest in Alfas too? I must admit to having owned and loved a few!
Best regards
John
