Jaguar X Type caliper bracket bolt
Old Nov 25, 2020 | 10:37 AM
JagXtypeV63.0L's Avatar
Default Jaguar X Type caliper bracket bolt
Hi I'm Andrew, I recently bought a Jaguar X Type and one of the front Caliper bracket bolts/ mounting bolts fell out while driving. I was wondering if anyone knows of where to find them. I can't find anything online for sale.
Old Nov 25, 2020 | 11:02 AM
NBCat's Avatar
Easiest method would be to remove the remaining one and find a similar bolt at a hardware shop.
Old Nov 25, 2020 | 11:35 AM
Default Thanks
Ill have to do that, it seems like there is no other way to find the same bolt.
Old Nov 25, 2020 | 04:15 PM
Dell Gailey's Avatar
Yeah, it's a tough one...
Just a caution, brake bolts (& some others) are different in strength, etc. than normal bolts & for good reason. If replacing, make sure it is of equal or greater rating.
https://www.jaguarforum.com/threads/...ng-pins.69853/
https://www.ebay.com/itm/for-JAGUAR-...3-dd474ef03c26
https://www.ebay.co.uk/itm/JAGUAR-X-....c101096.m3021
Old Nov 25, 2020 | 06:14 PM
Default Bolt
Would a ford Caliper bracket bolt work? I know most of the parts are ford.
Old Nov 25, 2020 | 08:03 PM
Most parts are NOT Ford. So tired of this uninformed, short sighted, misconception.
Old Nov 25, 2020 | 09:37 PM
Man on the hill's Avatar
Dell,
Hate to burst your bubble but the front brake calliper is the same part used on the ford mondeo mk3.
The front brake discs are the same part, and the mondeo mk3 front lower wishbone and hub/knuckle are the same.
Whilst the mondeo front strut is physically the same (and will fit), jaguar specified a twin tube strut, instead of the mondeo's single tube strut.
With all of the above info, I would bet on the caliper's carrier bracket being the same, so I would say the carrier bolts would also be the same.
Just double checked, and yes the carrier is the exact same part, so the bolts will be the same.
Paul.
Old Nov 25, 2020 | 11:52 PM
Yeah forgot my own post on the video of removing the front arm (w/ball joint) being PRECISELY the same as the X. Video is a Mondeo.
Old Nov 26, 2020 | 05:28 AM
Jo van Haag's Avatar
Yes I can confirm the brakes are the same as Ford Mondeo mk3. The disassembly "front lower wishbone and hub/knuckle" are not as easy as you can see in the video.
orangeblossom
Sep 20, 2016 01:24 AM
orangeblossom
Sep 27, 2015 11:32 AM
jross4892
Feb 27, 2015 06:35 PM
rigmover2307
XJ40 ( XJ81 )
Sep 20, 2010 08:56 PM
Fedekz
Jul 20, 2009 06:51 AM
