Jaguar X Type gas no filling
Old Mar 31, 2016 | 07:44 PM
Noel619's Avatar
Default Jaguar X Type gas no filling
Hello i have a 2003 Jaguar X-Type 2.5 v6 automatic and when i add fuel to it the pump stops filling like if the tank is full. I have to slightly press the fuel pump slowly so the gas can go through perfectly without stopping. I add Premium gas which is the best gas. I just want to know if im the only one that has this problem or other people experience it. Also if theres a way to fix it
Old Mar 31, 2016 | 09:37 PM
harryc's Avatar
Don't insert the pump nozzle all the way in. There are usually springs around the base of the nozzle that are used as a rest. Keep the nozzle 50% out and put it down on the coil.
Old Apr 1, 2016 | 08:00 AM
avern1's Avatar
I had the same problem on my XJ8. Attached is a service bulletin for correcting it on mine. It might be worth looking into for your problem.
File Type: pdf
Old Apr 3, 2016 | 04:03 AM
flyrr100's Avatar
I get the same problem. The only way I can completely fill my tank is to pump at a ridiculously slow rate. But it works.
Old Apr 3, 2016 | 08:01 AM
Jac's Avatar
Jac
I remember seeing this and it really worked. Read post:https://www.jaguarforums.com/forum/x...my-car-125929/
Old Apr 3, 2016 | 11:30 AM
Larry-Cleveland's Avatar
Generally it is a problem with the tank venting. When putting in fuel, air (fumes) must come out. If they are not coming out they will back up the filler neck and trip off the sensor in the fuel nozzle stopping the flow of fuel.
Old Apr 3, 2016 | 12:28 PM
sov211's Avatar
As has been stated, simply pulling the nozzle out a bit to permit air escape while filling solves this issue instantly; this same "problem" is found on many modern cars.
Old Apr 4, 2016 | 08:18 AM
DPK's Avatar
DPK
My 2003 had a slow fill issue too..I got use to just putting in fuel slowly with nozzle almost out.
Tomica
Other Areas
Sep 20, 2017 01:50 AM
benpearce2013
Apr 21, 2016 08:27 AM
FastCat85
Mar 22, 2016 10:27 AM
Coleman Ray Briggs
Mar 12, 2016 01:56 AM
ktr
Jan 10, 2011 09:44 AM
